Re: error using UML as input [message #890087 is a reply to message #887559] |
Thu, 21 June 2012 03:19 |
Hi, Fernanda,
You will probably get better help about ATL on the ATL forum than on
the UML2 forum. This doesn't seem likely to be specific to the UML
metamodel, as such.
Christian
On 2012-06-16 20:54:12 +0000, Fernanda R.F. said:
> I'm trying to use ATL plugin, but I'm getting the following error:
> org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model
> element Model from UML
> Java Stack:
> at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM.java:243)
> at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:195)
> at
> org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
> at
> org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch(EMFVMLauncher.java:139)
> at uml2metamodelRC.Uml2metamodel.doUml2metamodel(Uml2metamodel.java:165)
> at uml2metamodelRC.Uml2metamodel.main(Uml2metamodel.java:80)
> Caused by:
> org.eclipse.m2m.atl.engine.emfvm.ASM$SignatureParsingException: Could
> not find model element Model from UML
> at org.eclipse.m2m.atl.engine.emfvm.ASM.parseTypeInternal(ASM.java:414)
> at org.eclipse.m2m.atl.engine.emfvm.ASM.parseType(ASM.java:378)
> at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM.java:240)
> ... 5 more
> I'm using an UML file as metamodel in and an Ecore file as metamodel out.
> I tried change sending a URL instead of UML metamodel, however the
> error still occurring.
> So, what could I do to resolve it?
> Thanks
FUDForum. Page generated in 0.03006 seconds
