Home » Language IDEs » ServerTools (WTP) » Odd behavior when publishing web project with deps
Odd behavior when publishing web project with deps [message #117778] |
Thu, 07 July 2005 21:22  |
Originally posted by: ccostello.stubhub.com
Hello all,
I've created a dynamic web app foo and a util java project bar. Foo only
contains the default web application contents plus a simple, "Hello,
world!" index.jsp. Bar contains default contents (nothing) plus one
class, test.TestClass, that's comprised of a public constructor and
nothing else.
Before establishing any relationship between the projects, I can
successfully associate the web app with a server and
launching/stopping/publishing to Tomcat works fine.
However, as soon as I create a "Java Jar Dependency" within foo upon bar,
I can no longer run the Tomcat server. In the Servers view, status is
reported as "Stopped", and state is reported as "Republish". Trying to
start the server has no visible effect on anything, and nothing new shows
up in the console or .log file. Attempting to "Publish" foo (by
right-clicking on the server in the servers view) results in a
java.util.ConcurrentModificationException in the .log file. (See full
entry below).
If I remove the dependency, all returns to normal, expected behavior.
Deleting/recreating the server config has no effect. Restarting eclipse
(with and without -clean) has no effect. Restarting my machine has no
effect. The scenario is always reproducible.
I'm using Tomcat 5.5.9, jdk 5.0 update 3, windows xp pro sp2, eclipse 3.1
final and WTP M5. Is anyone else experiencing anything like this?
Thanks for reading,
-Cass
!ENTRY org.eclipse.ui 4 0 2005-07-07 18:15:35.355
!MESSAGE java.util.ConcurrentModificationException
!STACK 0
at java.util.AbstractList$Itr.checkForComodification(Unknown
Source)
at java.util.AbstractList$Itr.next(Unknown Source)
at
org.eclipse.wst.server.core.internal.PublishServerJob.<init >(PublishServerJob.java:66)
at
org.eclipse.wst.server.ui.internal.view.servers.PublishActio n.perform(PublishAction.java:
52)
at
org.eclipse.wst.server.ui.internal.view.servers.AbstractServ erAction.run(AbstractServerAc
tion.java:53)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionI
tem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java
:400)
at
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
Re: Odd behavior when publishing .. works after fresh install. [message #118762 is a reply to message #117778] |
Fri, 08 July 2005 18:33  |
After deleting 3.1 and reinstalling, everything now works as expected.
Before trying that, I tried (one last time) working from a new workspace
to no avail.
Now, foo starts/stops/publishes correctly even with the dependency. I had
started from a fresh install yesterday, too, so I remain confused. :)
On another note...
I've added a few more deps to foo, including log4j. A new servlet class
loads a log4j config file held inside WEB-INF appropriately. The config
file specifies a default loggin threshold of "debug," however, only
statements at level "info" and above are output to the eclipse console
when I launch Tomcat.
Debugging demonstrates that log.isDebugEnabled() returns false throughout
my codebase. Is there some special sauce required to get log4j, Tomcat,
Eclipse and WTP to play together nicely? I include the log4j config info
below...
Thanks again for everyone's time.
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/">
<appender name="ConsoleAppender"
class="org.apache.log4j.ConsoleAppender">
<layout class="org.apache.log4j.PatternLayout">
<param name="ConversionPattern" value="%d{ISO8601} [%t] %p - %m%n"/>
</layout>
</appender>
<root>
<level value="debug" />
<appender-ref ref="ConsoleAppender"/>
</root>
</log4j:configuration>
Cass Costello wrote:
> Hello all,
> nothing else.
> entry below).
> Thanks for reading,
> -Cass
> !STACK 0
> Source)
> at
> at
> 52)
> at
> tion.java:53)
> at
> tem.java:538)
> at
> at
> :400)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Wed May 21 18:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.06268 seconds
