problem to connetc to marketplace on indivo realese 2 [message #887020] |
Fri, 15 June 2012 20:41  |
Hello, i've a problem to connect my eclipse indigo release 2 JEE with marketplace to download the jboss tools...
LOG
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at org.eclipse.equinox.internal.p2.ui.discovery.wizards.CatalogViewer.updateCatalog(CatalogViewer.java:563)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.updateCatalog(MarketplaceViewer.java:453)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage$6.run(MarketplacePage.java:332)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand.execute(MarketplaceWizardCommand.java:171)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.IllegalStateException
at org.eclipse.equinox.internal.p2.discovery.Catalog.performDiscovery(Catalog.java:64)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.performDiscovery(MarketplaceCatalog.java:255)
at org.eclipse.equinox.internal.p2.ui.discovery.wizards.CatalogViewer$6.run(CatalogViewer.java:569)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
THE LOG:
Code: [Select all] [Show/ hide]
Solutions?
Everytimes i go to marketplace or ceck updates or installa new software there is the same problem, the connection Unable to read repository
FUDForum. Page generated in 0.04505 seconds
