Home » Modeling » TMF (Xtext) » Trying to include templates.xml in xtext plugin
Trying to include templates.xml in xtext plugin [message #885756] Wed, 13 June 2012 14:36 Go to next message
Tim Student is currently offline Tim StudentFriend
Hi Guys,
I just read how to include templates out of an xml file to my Xtext plugin, but anyhow, it does not work. Therefore, I try to explain, what I have done. Hopefully someone can help me.
I created some templates out of the Window -> preferences page of my local eclipse-installation. Then I exported theese templates to an templates.xml.
I created a folder called templated in the org.xtext.xyz.mydsl.ui project, on the same directory level, as the src directory. I copied the templates.xml file inside it.
The content of my build.properties of the ui project looks like:
source.. = src/,\
          src-gen/
bin.includes = META-INF/,\
               plugin.xml,\
               templates/
Have I somehow missed anything? I ran the mwe2 Workflow, generated the xtext artifacts and exported the plugin to the jar. files. When I include the file on another eclipse installation, the templates page in the preferences menu remains empty:-(
Thanks so far guys!
Re: Trying to include templates.xml in xtext plugin [message #885763 is a reply to message #885756] Wed, 13 June 2012 14:41 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi have you codetemplatesgeneratorfragment added to the workflow and
did you merge plugin.XML_Gen and plugin.xml?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Trying to include templates.xml in xtext plugin [message #885769 is a reply to message #885763] Wed, 13 June 2012 14:58 Go to previous messageGo to next message
Thanks for your reply.
The codetemplatesgeneratorfragment is present in the workflow.
But I am wondering, because the plugin.xml_gen and plugin.xml have equal content.
Do you have any Idea?
Re: Trying to include templates.xml in xtext plugin [message #885771 is a reply to message #885756] Wed, 13 June 2012 14:58 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Tim,
you have to add ID tags to the exported templates in the XML file. See
the reference docs for details.
Sebastian
Am 13.06.12 16:36, schrieb Tim Student:
> Hi Guys,
> templates.xml.
> source.. = src/,\
> src-gen/
> plugin.xml,\
> templates/
> Thanks so far guys!
Re: Trying to include templates.xml in xtext plugin [message #885775 is a reply to message #885769] Wed, 13 June 2012 15:07 Go to previous messageGo to next message
No can you try it with a brand new mydsl project?
Re: Trying to include templates.xml in xtext plugin [message #885776 is a reply to message #885771] Wed, 13 June 2012 15:11 Go to previous message
That helped, great thanks to all of you!!!
Previous Topic:STRING serialization not producing quotes if no whitespace
Next Topic:Antlr equivalent to the '&' operator
Current Time: Sun May 16 18:04:47 GMT 2021
Powered by FUDForum. Page generated in 0.02337 seconds
