Home » Archived » Test and Performance Tools Platform (TPTP) » AGR Verification Hooks and datapools
AGR Verification Hooks and datapools [message #117368] Tue, 06 November 2007 15:53 Go to next message
Jason Levine is currently offline Jason LevineFriend
I'm using AGR with TPTP 4.4. I have created a test suite with a test case
and a datapool. The same test case is executed multiple times in the test
suite using different values from the datapool. The test case also has a
verification hook.
Is it possible to access the datapool from an AGR verification hook? I'd
like to be able to check if the view control contains data from variables
in the datapool.
Thank you,
Jason
Re: AGR Verification Hooks and datapools [message #117491 is a reply to message #117368] Wed, 07 November 2007 11:12 Go to previous message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Jason,
Yes. You can follow the steps in this tutorial:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. hyades.test.doc.user/samples/saccessdp.htm
Paul
"Jason Levine" <Jason.Levine@softwareagusa.com> wrote in message
news:61eabe77163b755fd76a015ae9b5064d$1@www.eclipse.org...
> verification hook.
> in the datapool.
> Thank you,
> Jason
Previous Topic:Parameter in TPTP HTTP Recordings
Next Topic:Integrated Agent Controller(IAC) was not found. Make sure you have IAC installed
Current Time: Mon Feb 17 21:26:50 GMT 2020
Powered by FUDForum. Page generated in 0.02403 seconds
