XTend 2.2.1 installation broken? (NPE at BuilderParticipant.java:184) [message #885192] |
Tue, 12 June 2012 15:28 |
Sven Kasten Messages: 8 Registered: May 2011 |
I have problems with my XText project (and also the XTend example projects). When I delete the generated files in xtend-gen, open up the .xtend file and save it (so the generator should be triggered I think), I get following stacktrace in the eclipse log/console
178 [Worker-5] ERROR org.eclipse.xtext.builder.impl.XtextBuilder -
at org.eclipse.xtext.builder.BuilderParticipant.isEnabled(BuilderParticipant.java:184)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:99)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:160)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:141)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:91)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Seems that something is wrong with my eclipse setup?! It worked fine the first time but after a time of work the described error occurs. This leads to a missing generator for my XText project.
Tried project -> clean but the error also occurs there. Also a new Workspace didn't help, so I guess it's something wrong with my installation. Any tips here what I can do now?
Kind regards
Sven
[Updated on: Tue, 12 June 2012 15:29] Report message to a moderator
FUDForum. Page generated in 0.03132 seconds
