Home » Archived » Koneki » [SOLVED] Koneki Deliverables?(Request for official/src/drop-in deliverables)
[SOLVED] Koneki Deliverables? [message #885100] |
Tue, 12 June 2012 13:21 |
Hi all,
We are trying to integrate the Koneki LUA Feature into an eclipse product. Our eclipse product is a mix of existing open source features and in-house developped eclipse features. In order to be compliant with the EPL license, we need to be able to deliver the sources from everything we deliver (both in-house and externally integrated features).
Currently we are using the 'SDK' drop-in variants from external features to integrate them in our own site.xml based update-site (we did not implement a p2 variant yet). Hence the following questions/requests:
(a) Currently Koneki is available through a P2 update-site which runs in nightly build mode. Is there a plan to provide a site with stable release deliveries?
(b) Is is possible to also provide the Koneki feature in a dropin's compatible archive, preferrably also offering an SDK variant (src+bin)?
(c) Will the source also be offered as a seperate feature in the future?
(d) What is the plan on official/stable deliveries on the Koneki project?
Bart
[Updated on: Tue, 14 May 2013 15:11] by Moderator Report message to a moderator
Re: Koneki Deliverables? [message #885126 is a reply to message #885100] |
Tue, 12 June 2012 13:59 |
Hello Bart!
Quote:We are trying to integrate the Koneki LUA Feature into an eclipse product.
Hey, that's awesome!
Quote:(a) Currently Koneki is available through a P2 update-site which runs in nightly build mode. Is there a plan to provide a site with stable release deliveries?
Sure, the final 0.8 version will be with Juno at the end of the month. Regular 0.8 milestones have been published on the eclipse.ialto.org/koneki/releases/0.8milestones update site (N-1 milestones are usually archived when a new milestone is out).
We've been releasing the milestones according to the project plan.
Quote:(b) Is is possible to also provide the Koneki feature in a dropin's compatible archive, preferrably also offering an SDK variant (src+bin)?
What are the requirements to do so? I guess you'd like to be able to download a zip corresponding to the org.eclipse.koneki.ldt feature, right? Please open a bug and I'd be glad to investigate this, it should be pretty straightforward. You might even contribute the patch yourself if you're familiar with Tycho! -- Tycho is awesome, btw.
Quote:(c) Will the source also be offered as a seperate feature in the future?
Just to be sure, you want a source feature, that's it? Again, please open a bug!
Quote:(d) What is the plan on official/stable deliveries on the Koneki project?
We will work on the 0.9 plan right after the 0.8 release. We'd like to release 0.9 by the end of the year and graduate (1.0) with Kepler next year.
We will probably run a poll to gather feedback before scheduling the work items for 0.9, but one thing we have on our plate is to refactor some of the plug-ins to make it clearer what's API and what's not, and improve the overall architecture. You should expect API changes before 1.0 (this is why 0.xs are for right? ), but maybe if you could share a bit more about the kind of integration you're willing to do, maybe we can take extra-care when refactoring things up. For example, do you plan on "just" shipping LDT , or will you extend wizards, preferences, templates, etc...
Cheers!
Benjamin.
My blog: http://blog.benjamin-cabe.com
Re: Koneki Deliverables? [message #893035 is a reply to message #891732] |
Mon, 02 July 2012 11:47 |
Hi Benjamin,
My request in topic (b) became irrelavant in our project, because I refactered our build system to be P2 compliant. I created some helper scripts which make a diff on eclipse/features and eclipse/plugins before and after the installation of a new feature through an update site. Then I use this list to generated out own self-contained P2 compatible update site.
With regards to topic (a) and (d), I took the update site from eclipse.ialto.org/koneki/releases/0.8milestones, which is good enough for now.
With regards to topic (c), I've just created a [bug/feature request] for it: hxxps://bugs.eclipse.org/bugs/show_bug.cgi?id=384030
BR,
Bart
[Updated on: Mon, 02 July 2012 11:49] Report message to a moderator
Re: Koneki Deliverables? [message #893036 is a reply to message #893035] |
Mon, 02 July 2012 11:57 |
Bart Van Bos wrote on Mon, 02 July 2012 13:47
Oops it looks like I gave you an URL towards a mirror, which, even though it should be fine, is probably not a good idea. I must have done a mistake with my clipboard...
It's probably better for you to rely on this URL: http://download.eclipse.org/koneki/releases/0.8milestones
Bart Van Bos wrote on Mon, 02 July 2012 13:47Hi Benjamin,
With regards to topic (c), I've just created a [bug/feature request] for it: https://bugs.eclipse.org/bugs/show_bug.cgi?id=384030
Great, thanks for that!
Benjamin
Re: Koneki Deliverables? [message #1416495 is a reply to message #885126] |
Mon, 25 June 2012 16:17 |
Hi Bart,
Are the answers OK with you? Is there anything else you'd need?
That would be super cool if you could take some time to file the couple bugs that will allow you to trace your requests.
Thank you!
Ben
Re: Koneki Deliverables? [message #1416500 is a reply to message #891732] |
Hi Benjamin,
BR,
Bart
Re: Koneki Deliverables? [message #1416501 is a reply to message #893035] |
> Hi Benjamin,
Benjamin
Current Time: Sat Apr 20 00:41:33 GMT 2024
Powered by FUDForum. Page generated in 0.04975 seconds
