HTML editor does not open [message #117247] |
Thu, 07 July 2005 04:43  |
Hello !
I have just installed the WTP M5 and tried working with it. I have
installed the pre-requists, and when I the first thing I have tried doing
was opening an HTML document.
For some reason I do not get the editor, but rather :
"Unable to create this part due to an internal error. Reason for the
failure: Editor could not be initialized."
and then :
"java.lang.NoClassDefFoundError:
org/eclipse/wst/common/uriresolver/internal/provisional/URIR esolver
at
org.eclipse.wst.html.core.internal.encoding.HTMLModelLoader. getAdapterFactories(HTMLModelLoader.java:73)
at
org.eclipse.wst.sse.core.internal.model.AbstractModelLoader. createModel(AbstractModelLoader.java:114)
at
org.eclipse.wst.sse.core.internal.FileBufferModelManager.get Model(FileBufferModelManager.java:470)
What am I doing wrong ?
Thank you !
Elad
Re: HTML editor does not open [message #117495 is a reply to message #117469] |
Thu, 07 July 2005 11:07  |
Originally posted by: dombat.gmail.com
Regards, Cordialement,
Dominique Batard
MDSP Project - Functional Integration
Phone : 33 (0)1 14 53 27
Tie : 765327
mailto: dominique@ixemel.net
David Williams a écrit :
> On Thu, 07 Jul 2005 08:18:41 -0400, Elad Messing
> <elad.messing@gmail.com> wrote:
>> Hello again
>> Well - I did a fresh installation and than everything works.
>> Than I started adding each plug-in - one by one.
>> It seems that the Hibernate Tools plugin is causing all the trouble.
>> More specifically - the directories "org.eclipse.wst.xml.*" which are
>> bundeled in the Hibernate tools "plugins" directory.
>> Does you already know about this problem ? Havnt seen it in the Eclipse
>> documanted nor with the Hibernate plugin documantation.. Is it a known
>> bug
> !!!! Its a surpise to me ... where does the hibernate tools come from?
> Seems clearly they should not be re-distributing and are probably only
> doing
> so as a temporary measure to have a fixed version of the xml stuff. (If
> they are
> actually modifing the code and redistributing, its even worse, but I
> suspect
> again, their plan is only temporary). I'd open a bug on them (and CC me :)
> Thanks for much for digging in and helping find the source of the problem.
I've got the same trouble with hibernate tools. I've solved it by
selecting and only extracting the org.hibernate.eclipse.* stuff.
Dom
FUDForum. Page generated in 0.05548 seconds
