Oracle WLS fails to start with proxy enabled [message #892138 is a reply to message #884626] |
Wed, 27 June 2012 08:08 |
SOPAN MISHRA Messages: 1 Registered: June 2012 |
Zack Macomber wrote on Mon, 11 June 2012 23:03What's odd is that WLS IS starting...I can open up my web application and also go to the WLS console home no problem. But, Eclipse is giving me a failure message and ultimately not showing it as started...
I'm facing the same issue with indigo+weblogic 10.3.5 though weblogic 8.1 works fine.
I can start my domain locally but on configuring from eclipse I get the error-Stopped, Unable to validate WebLogic Domain
I googled and the nearest I could get was --
"forevergarden17.blogspot.in/2011/02/stopped-unable-to-validate-weblogic.html"
--(when eclipse is working on java 6 (and it has to, because oracle development tools for helios requires java 6) and weblogic is running on java 5.
The workaround is simple:
add
-Dsun.lang.ClassLoader.allowArraySyntax=true
after -vmargs string in eclipse.ini)
which doesn't seem relevant or helpful in my case
Wish somebody could shed some light on the topic.
[Updated on: Wed, 27 June 2012 08:09] Report message to a moderator
FUDForum. Page generated in 0.03123 seconds
