Home » Archived » Test and Performance Tools Platform (TPTP) » agent library failed to init: JPIBootLoader
agent library failed to init: JPIBootLoader [message #117006] Fri, 02 November 2007 17:20 Go to next message
Originally posted by: wjfang.gmail.com
When I run "java -agentlib:JPIBootLoader=JPIAgent:help", I got the following
error message:
"Error occurred during initialization of VM
agent library failed to init: JPIBootLoader"
java: 1.6.0_03
OS: windows xp pro
TPTP agent controller: agntctrl.win_ia32-TPTP-4.4.0.3
I have added %TPTP_AC_HOME%\bin and
%TPTP_AC_HOME%\plugins\org.eclipse.tptp.javaprofiler to the system path
variable.
How can I run JVM in the tptp profiling mode? Many thanks in advance!
Jerry
Re: agent library failed to init: JPIBootLoader [message #117049 is a reply to message #117006] Sat, 03 November 2007 02:34 Go to previous messageGo to next message
Chris Elford is currently offline Chris ElfordFriend
Can you check out
http://wiki.eclipse.org/TPTP-standalone-script-TPTP4.4.0.3 and let me know
if this helps? I have two examples of environment variables for windows.
One uses the standalone agent controller and the other is set up for the
embedded agent controller.
thx,
chris
Re: agent library failed to init: JPIBootLoader [message #117072 is a reply to message #117049] Sun, 04 November 2007 22:56 Go to previous message
Thanks! after i set up JAVA_PROFILER_HOME, it works.
"Chris Elford" <chris.l.elford@intel.com> wrote in message
news:9ba85bbb09cca65019c313b84e6fb818$1@www.eclipse.org...
> Can you check out
> thx,
> chris
Previous Topic:Nondeterministic Profiler Trace import
Next Topic:Can not profile tomcat
Current Time: Wed Feb 19 22:48:26 GMT 2020
Powered by FUDForum. Page generated in 0.03477 seconds
