Home » Modeling » TMF (Xtext) » problems with the OnTheFlyJavaCompiler
problems with the OnTheFlyJavaCompiler [message #883856] |
Sat, 09 June 2012 15:41 |
I'm using the CompilationTestHelper (which relies on
OnTheFlyJavaCompiler) for testing that the generated Java code for my
DSL is Java correct; this works fine but for one case: in my DSL for
each input "entity" I generate two Java classes, say, a.A1 and a.b.A2,
where A2 "depends" on A1 (e.g., it has a field of type A1). When
CompilationTestHelper compiles A1 everything goes fine; when then it
compiles A2 the java compiler says it cannot find A1.
By debugging I found one problem:
- the classpath used by the OnTheFlyJavaCompiler does not contain the
temporary folder (where a.A1.class was compiled), and I can deal with
that with an injected custom OnTheFlyJavaCompiler which does
public String getClasspathArgs() {
final String classpathArgs = super.getClasspathArgs();
return classpathArgs
+ (classpathArgs.isEmpty() ? "" : File.pathSeparator +
createTempDir().getAbsolutePath() + File.separator);
this way, if I manually call the java compiler (javac) from the command
line (while the junit test is stopped in debugging mode and the java
file for A2 is in the temporary folder), everything compiles fine.
However,
- In spite of the now correct classpath, the OnTheFlyJavaCompiler still
complains that it cannot find A1, while compiling A2...
Is there any workaround?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: problems with the OnTheFlyJavaCompiler [message #884468 is a reply to message #883856] |
Mon, 11 June 2012 06:17 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi Lorenzo,
could you please file a bugzilla?
Sven
Am 6/9/12 5:41 PM, schrieb Lorenzo Bettini:
> Hi
> @Override
> File.separator);
> However,
> thanks in advance
> Lorenzo
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: problems with the OnTheFlyJavaCompiler [message #884528 is a reply to message #884468] |
Mon, 11 June 2012 09:03 |
Yes,
in the meantime a possible solution I found was to compile all the java
sources in a single command (using a custom OnTheFlyJavaCompiler); I'll
file the bug ASAP.
cheers
Lorenzo
On 06/11/2012 08:17 AM, Sven Efftinge wrote:
> Hi Lorenzo,
> Sven
>> Hi
>> @Override
>> File.separator);
>> However,
>> thanks in advance
>> Lorenzo
Re: problems with the OnTheFlyJavaCompiler [message #894969 is a reply to message #884468] |
Wed, 11 July 2012 09:29 |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=384809
> Hi Lorenzo,
> Sven
>> Hi
>> @Override
>> File.separator);
>> However,
>> thanks in advance
>> Lorenzo
Current Time: Fri Apr 19 03:58:34 GMT 2024
Powered by FUDForum. Page generated in 0.02615 seconds
