Home » Eclipse Projects » EclipseLink » Problems with @Id in mapped superclasses
Problems with @Id in mapped superclasses [message #882530] Wed, 06 June 2012 16:47 Go to next message
Dan Bernstein is currently offline Dan BernsteinFriend
I seem to be getting the same error as described in bug 288972, even though the bug has been marked fixed and closed.
Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: An internal error occurred accessing the primary key object [202].
Internal Exception: java.lang.NoSuchFieldException: effective
Descriptor: RelationalDescriptor(com.dst.hps.pmab.product.bom.PlanEffectiveData --> [DatabaseTable(PLAN_EFF_DATA)])
Runtime Exceptions:
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:535)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:476)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:435)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:676)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:634)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:208)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.invokeProxyMethod(AbstractEntityManagerFactoryBean.java:423)
	at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean$ManagedEntityManagerFactoryInvocationHandler.invoke(AbstractEntityManagerFactoryBean.java:485)
	at $Proxy737.createEntityManager(Unknown Source)
	at org.springframework.orm.jpa.SharedEntityManagerCreator$SharedEntityManagerInvocationHandler.invoke(SharedEntityManagerCreator.java:234)
	at $Proxy738.createQuery(Unknown Source)
	at org.eclipse.persistence.jpa.JpaHelper.createQuery(JpaHelper.java:123)
	at com.dst.hps.pmab.common.dao.eclipselink.BaseEclipseLinkDAO.convertToJPAQuery(BaseEclipseLinkDAO.java:175)
	at com.dst.hps.pmab.common.dao.eclipselink.EclipseLinkDAO.getObject(EclipseLinkDAO.java:926)
	at com.dst.hps.pmab.dao.eclipselink.EclipseLinkSecurityDAO.getSecurityPolicy(EclipseLinkSecurityDAO.java:64)
	at com.dst.hps.pmab.security.impls.PMABSecurityImpl.getSecurityPolicy(PMABSecurityImpl.java:156)
	at com.dst.hps.pmab.security.impls.PMABSecurityImpl.getPublicSecurityPolicy(PMABSecurityImpl.java:84)
	at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
	at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
	at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
	at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
	at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
	at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
	at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
	at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
	at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_2123954626.invoke(InvocationContextInterceptor_z_fillMethod_2123954626.java)
	at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
	at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_2123954626.invoke(InvocationContextInterceptor_z_setup_2123954626.java)
	at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
	at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
	at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
	at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
	at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
	at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
	at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
	at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
	at org.jboss.ejb3.security.RoleBasedAuthorizationInterceptorv2.invoke(RoleBasedAuthorizationInterceptorv2.java:201)
	at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
	at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
	at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
	at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
	at org.jboss.ejb3.stateless.StatelessContainer.dynamicInvoke(StatelessContainer.java:421)
	at org.jboss.ejb3.remoting.IsLocalInterceptor.invokeLocal(IsLocalInterceptor.java:85)
10:03:47,128 INFO  [STDOUT] erceptor.invoke(IsLocalInterceptor.java:72)
	at org.jboss.aspects.remoting.PojiProxy.invoke(PojiProxy.java:62)
	at $Proxy733.invoke(Unknown Source)
	at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
	at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
	at $Proxy713.getPublicSecurityPolicy(Unknown Source)
	at com.dst.hps.pmab.ui.AppHelper.getSecurityPolicy(AppHelper.java:22)
	at org.apache.myfaces.el.PropertyResolverImpl.getProperty(PropertyResolverImpl.java:457)
	at org.apache.myfaces.el.PropertyResolverImpl.getValue(PropertyResolverImpl.java:85)
	at com.sun.facelets.el.LegacyELContext$LegacyELResolver.getValue(LegacyELContext.java:141)
	at com.sun.el.parser.AstValue.getValue(Unknown Source)
	at com.sun.el.ValueExpressionImpl.getValue(Unknown Source)
	at com.sun.facelets.el.ELText$ELTextVariable.writeText(ELText.java:184)
	at com.sun.facelets.el.ELText$ELTextComposite.writeText(ELText.java:108)
	at com.sun.facelets.compiler.TextInstruction.write(TextInstruction.java:45)
	at com.sun.facelets.compiler.UIInstructions.encodeBegin(UIInstructions.java:39)
	at com.sun.facelets.tag.jsf.ComponentSupport.encodeRecursive(ComponentSupport.java:242)
	at com.sun.facelets.tag.jsf.ComponentSupport.encodeRecursive(ComponentSupport.java:249)
	at com.sun.facelets.FaceletViewHandler.renderView(FaceletViewHandler.java:596)
	at org.apache.myfaces.trinidadinternal.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:182)
	at org.apache.myfaces.lifecycle.RenderResponseExecutor.execute(RenderResponseExecutor.java:41)
	at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:132)
	at javax.faces.webapp.FacesServlet.service(FacesServlet.java:140)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at org.apache.myfaces.trinidadinternal.webapp.TrinidadFilterImpl._invokeDoFilter(TrinidadFilterImpl.java:250)
	at org.apache.myfaces.trinidadinternal.webapp.TrinidadFilterImpl._doFilterImpl(TrinidadFilterImpl.java:207)
	at org.apache.myfaces.trinidadinternal.webapp.TrinidadFilterImpl.doFilter(TrinidadFilterImpl.java:161)
	at org.apache.myfaces.trinidad.webapp.TrinidadFilter.doFilter(TrinidadFilter.java:92)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at org.springframework.web.filter.RequestContextFilter.doFilterInternal(RequestContextFilter.java:83)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:368)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:380)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:97)
	at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:100)
	at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:78)
	at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:54)
	at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:35)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:187)
	at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:105)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:79)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:169)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
	at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
	at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
	at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
	at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
	at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:383)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
	at java.lang.Thread.run(Thread.java:662)
I am using EclipseLink 2.3.2.v20111125-r10461 on Windows 7 under JBoss.
My code is as follows. I have an inheritance chain involving 3 classes:
@MappedSuperclass
public abstract class PersistableObject implements java.io.Serializable
    @Id @GeneratedValue(...)
    @Column(name = "ID", nullable = false, updatable = false)
    private Long id ;
Derived class:
@MappedSuperclass
@IdClass(PersistableId.class)
public abstract class HistorySlice extends PersistableObject
    @Column(name="RECORDED", nullable=false, updatable=false)
    @Temporal(TemporalType.TIMESTAMP)
    @Id
    private Date recorded;
Derived class:
@MappedSuperclass
@IdClass(TemporalId.class)
public class TemporalSlice extends HistorySlice implements Serializable...
    @Column(name="EFFECTIVE", nullable=false, updatable=false)
    @Temporal(TemporalType.DATE)
    @Id
    private Date effective ;
And here is my entity class:
@Entity
@Table(name = "PLAN_EFF_DATA")
public class PlanEffectiveData extends TemporalSlice
My ID classes are as follows:
@Embeddable
public class PersistableId implements java.io.Serializable...
    @Column(name="ID", nullable=false)
    private Long id ;
    @Column(name="RECORDED", nullable=false)
    private Date recorded ;
And finally
@Embeddable
public class TemporalId implements java.io.Serializable, Comparable<TemporalId>
    @Column(name="ID", nullable=false, updatable=false)
    private Long id ;
The crazy thing is that after I get the validation exception above, everything WORKS !!!
Can someone please explain, or help me out? It seems like the validation exception is erroneous, and there is some problem with EclipseLink.
Re: Problems with @Id in mapped superclasses [message #883014 is a reply to message #882530] Thu, 07 June 2012 16:38 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
I've filed bug 382029 and checked in a fix into trunk (2.5) to fix the error you are getting so that it prints off the pk class causing the exception instead of 202 (which is the error code).
The reason it seems to work is that the error occurs at the tail end of initializing the descriptor for PlanEffectiveData. When you continue on, it doesn't retry initializing this descriptor and will proceed. What hasn't been initialized are the fetch groups and the primary key class for the PlanEffectiveData; you will likely run into an issue if you attempt to use an em.find on the PlanEffectiveData class.
I will have to test what the issue is, but I suspect it is a processing problem where the PersistableId IDClass isn't being replaced with the TemporalId class. Can you try removing the IDClass annotations from HistorySlice and seeing if you get this same exception? Presumably you will have to exclude any Entities that directly extend HistorySlice to test that it works correctly.
Chris
Re: Problems with @Id in mapped superclasses [message #883045 is a reply to message #883014] Thu, 07 June 2012 18:12 Go to previous messageGo to next message
Please file a bug showing the classes and mappings as you have in the post. EclipseLink currently walking up the inheritance tree and is setting the pk class each time it encounters the setting - resulting in PersistableId being used instead of TemporalId. The workaround is to avoid setting the pkClass multiple times in an inheritance heirarchy.
Best Regards,
Chris
Re: Problems with @Id in mapped superclasses [message #893560 is a reply to message #883014] Wed, 04 July 2012 14:48 Go to previous message
vaidya nathan is currently offline vaidya nathanFriend
We are also having the same problem. Have a work around currently in place to have only one IdClass in the whole hierarchy . Will wait for Daniel to create the bug so that we can vote on it ..
Thx
Vaidya
Previous Topic:Informix table creation error
Next Topic:Persistence.xml question
Current Time: Thu Apr 25 06:45:23 GMT 2024
Powered by FUDForum. Page generated in 0.04281 seconds
