Re: Ecore model replacement [message #882478 is a reply to message #882439] |
Wed, 06 June 2012 14:29 |
Matthias N wrote on Wed, 06 June 2012 15:12Aurelien Pupier wrote on Wed, 06 June 2012 05:11Hi,
that's why modified @Generated Not is a bad practice (from my POV)
See the 5th slide of my talk: url...
Unfortunately, I'm not sure to understand your use case to answer with more details :s
How would you use the "@generated NOT"? Sorry but here at work they don't allow slideshare (so stupid).
I'm using the generated code only as a sandbox, to test quickly new features. Code is regenerated at each build.
You can use GMF-Tooling model, extension points and generation templates to make your customizations.
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Ecore model replacement [message #884742 is a reply to message #882478] |
Mon, 11 June 2012 18:07 |
Matthias N Messages: 66 Registered: June 2012 |
Member |
Aurelien Pupier wrote on Wed, 06 June 2012 10:29Matthias N wrote on Wed, 06 June 2012 15:12Aurelien Pupier wrote on Wed, 06 June 2012 05:11Hi,
Hi Aurelien, can you provide me more information about how and which "generation templates" you use ?
thank you very much
FUDForum. Page generated in 0.03389 seconds
