unable to add tomcat installation [message #116576] |
Wed, 06 July 2005 10:46 |
Originally posted by: joerg.eschke.net
I try to add a tomcat v5 to the Installed Server Runtime Environment within
the preferences but recieve "The Tomcat installation directory is not
correct. It does not point to a valid Tomcat installation." from the
wizard.
I am running 0.7m5 using the default tomcat 5 installation
provided by SuSE Linux 9.3
Any hints ?
How does the wizard determine a so called "valid" tomcat installation ?
Greets,
Joerg
Re: unable to add tomcat installation [message #116670 is a reply to message #116628] |
Wed, 06 July 2005 14:27 |
Originally posted by: zen.rem.this.debian.linux.org.pl
Larry Isaacs napisał(a):
> The Tomcat support expects the Tomcat installation to be under a single
> install directory, like what is found the tar.gz binary distributions
> that can be downloaded from Apache Jakarta. I assume the problem is
> that the Tomcat installation appears under multiple directories.
This is probably the reason. But in most distros (most means Debian is
this case ;) Tomcat installation is divided into multiple locations.
> Cheers,
> Larry
Tomasz 'Zen' Napierala
JID: tzn@jabber.org | GSM: 509694518
http://debian.linux.org.pl | http://www.alrauna.org
RLU: 312924 | Debian SID | Firefox 1.0
Re: unable to add tomcat installation [message #116768 is a reply to message #116682] |
Wed, 06 July 2005 15:49 |
Jörg Eschke Messages: 5 Registered: July 2009 |
Hmm, the directory structure doesn't seem to be the problems cause.
Using a SuSE Linux 9.1 installation where the tomcat directory structure is
identically the wizard does his job as expected.
Larry Isaacs wrote:
> I don't have a *nix system to play with at the moment, so I can't say
> exactly why the symlinks aren't being accepted. I'll see what I can
> find out. I don't know of a reason not to try to make this work.
> Cheers,
> Larry
> Jörg wrote:
>> the directory structure look like this:
>> /usr/share/tomcat5/
>> bin
>> common
>> conf -> /srv/www/tomcat5/base/conf
>> logs -> /srv/www/tomcat5/base/logs
>> server
>> shared
>> temp -> /srv/www/tomcat5/base/temp
>> webapps -> /srv/www/tomcat5/base/webapps
>> work -> /srv/www/tomcat5/base/work
>> You are right, after installing a Tomcat .tar.gz binary distribution from
>> the Apache Jakarta Page everything works fine.
>> Thanks,
>> Joerg
>>>If you identify your directory structure, I may be able to suggest how
>>>to trick the Tomcat support in to accepting that structure. You are
>>>also welcome to file an enhancement request in the Bug database.
>>>Cheers,
>>>Larry
>>>>within the preferences but recieve "The Tomcat installation directory is
>>>>not correct. It does not point to a valid Tomcat installation." from the
>>>>wizard.
>>>>Any hints ?
>>>>Greets,
>>>>Joerg
Re: unable to add tomcat installation [message #157710 is a reply to message #157622] |
Mon, 23 January 2006 17:58 |
Max Giesbert wrote:
> Has the problem finally been solved? I just expereience the same problem
> running wtp1.0 and tomcat5. i can't get the wizard to accept my
> directory as valid.
Does the layout of your Tomcat 5.0 directory differ from the layout
in the .zip/.tar files provided by Apache?
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 1.10578 seconds
