Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Texo ModelPackage already registered
Re: Texo ModelPackage already registered [message #881504 is a reply to message #881475] |
Mon, 04 June 2012 17:38 |
Hi Sebastian,
Hmm, what do you do the second time, restart the server?
Seems like a classloading issue, the ModelResolver has a static instance to keep track of the available ModelPackage,
when a generated ModelPackage is initialized it registers itself automatically in the ModelResolver. It seems that the
generated ModelPackage class is reloaded but not the ModelResolver class.
Yes the 3-tier is indeed interesting, the main pieces are there I only need to tie them together (the json server side
webservice with a remote EMF Resource), will be a few weeks/month from now I guess...
gr. Martin
On 06/04/2012 06:18 PM, Sebastian Steinacher wrote:
> Hello,
> we are evaluating Texo for a while now and are quite confident to use it in our next project. As I now started to also
> use the model features, besides the generated JPA classes, a problem arose. I'm not sure, if I'm using something in the
> wrong way. We deploy Texo on a Glassfish server, with the required jars in place. I my EJB I register the model package
> like this:
> ServiceModelPackageRegistry.getInstance().register(PersistenceModelPackage.INSTANCE);
> After starting Glassfish and deploying for the first time, everything works fine, but the second time I always get the
> following excpetion:
> Caused by: java.lang.IllegalStateException: The EcoreModelPackage with NsUri ... has already been registered!
> I already tried to find some hint in the Texo documentation and also watched the youtube videos. What am I missing?
> Thanks!
> Sebastian
> P. S. I'm quite curious about the 3. tier RCP features in Texo, this is exactly what we are looking for.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Texo ModelPackage already registered [message #881738 is a reply to message #881700] |
Tue, 05 June 2012 07:15 |
Hi Sebastian,
No the registry should not survive a redeploy. I have another user on the forum who encounters the same issue with
Teneo, it seems that not all classes are reloaded in a redeploy. I guess that it depends in which classloader a class is
loaded. Are all your Texo/EMF jars located inside the WEB-INF/lib directory?
After restarting, can you debug which classloader has loaded the ModelResolver class?
gr. Martin
On 06/05/2012 07:33 AM, Sebastian Steinacher wrote:
> Hello Martin,
> the problem only shows when I redeploy without restart of the server, after a server restart everything works fine for
> the first time. I tried to check if the URI of the model is already registered before registering it, but as soon as I
> use one of the static methods of the model package or factory I run into the same problem.
> Is the registry intended to survive a redeployment? What is the right way to use the model factory for the creation of
> my classes (I want to use the converter to EMF, therefore I instantiate with the factory)?
> Thanks & Regards
> Sebastian
The Netherlands
Current Time: Thu Apr 25 23:23:48 GMT 2024
Powered by FUDForum. Page generated in 0.03368 seconds
