Export to DOC Microsoft Word Issue [message #881456] |
Mon, 04 June 2012 15:36 |
Dejan Vujanic Messages: 67 Registered: October 2011 |
Member |
I previously had a problem with Cyrillic letters (they have not been pretty displayed ) to be shown in PDF when I export it from system.
So I changed fontsConfig.xml and fontsConfig_pdf.xml
I changed mapping:
<mapping name="serif" font-family="Arial Unicode MS" /> to Arial Unicode MS
and also encoding (this is for Cyrillic letters)
<encoding font-family="Arial Unicode MS" encoding="Cp1251" />
and also some composite font
<font font-family="Arial Unicode MS" catalog="Western" />
I changed this in this both files and now pdf is displayed correctly.
But now I have problem to export it to doc Microsoft Word:
when i export it in word non English letters are shown as little squares.
Font selected in word is Lucida Sans Typewriter.If I manually select text and then change font to Arial Unicode MS text is displayed OK.
So which file do I have to change for correct Word document?
Is it only fontsConfig_linux.xml???
I tried to put Arial Unicode Ms instead on Lucida Sans Typewriter on evry place (bolded one) but then I am getting format error corrupted document, and file is not opened!!!
<font>
<font-aliases>
<mapping name="sans serif" font-family="Lucida Sans" />
<mapping name="monospace" font-family="Arial Unicode MS" />
<mapping name="cursive" font-family="Arial Unicode MS" />
<mapping name="fantasy" font-family="Arial Unicode MS" />
</font-aliases>
<composite-font name="all-fonts" default="Arial Unicode MS">
<font font-family="ZYSong18030" catalog="Chinese" />
<font font-family="Baekmuk Batang" catalog="Korean" />
<font font-family="Kochi Mincho" catalog="Japanese" />
</composite-font>
</font>
What do I have to change for correct word document?
[Updated on: Mon, 04 June 2012 20:00] Report message to a moderator
Re: Export to DOC Microsoft Word Issue [message #881966 is a reply to message #881456] |
Tue, 05 June 2012 14:52 |
What version of BIRT are you using?
Jason
On 6/4/2012 11:36 AM, Missing name Mising name wrote:
> I previously had a problem with Cyrillic letters (they have been non
> pretty dispalyed ) to be shown in PDF when I export it from system.
> I changed mapping:
> squares. Font selected in word is Lucida Sans Typewriter.If I manually
> I tried to put Arial Unicode Ms instead on Lucida Sans Typewriter on one
> is not opened!!!
> <font>
> <font-aliases>
> <mapping name="serif" font-family="Lucida Bright" />
> <mapping name="monospace" font-family="Lucida Sans Typewriter" />
> <mapping name="cursive" font-family="Lucida Sans Typewriter" />
> <mapping name="fantasy" font-family="Lucida Sans Typewriter" />
> </font-aliases>
> <font font-family="Lucida Sans Typewriter" catalog="Western" />
> </composite-font>
> </font>
> Thanks
Re: Export to DOC Microsoft Word Issue [message #882669 is a reply to message #882483] |
Thu, 07 June 2012 00:07 |
Any chance you could try this in a later version of BIRT?
Jason
On 6/6/2012 10:42 AM, Missing name Mising name wrote:
> Thanks for reply Jason.
> I am using Eclipse 3.4.4 and
> org.eclipse.birt.report.engine.fonts_2.3.2.r232_20090202v
> do u know solution how to present it in Word also? I can not find such
> information on internet
Re: Export to DOC Microsoft Word Issue [message #883112 is a reply to message #882724] |
Thu, 07 June 2012 21:38 |
I do not think the word emitter uses fontsConfig. I wanted you to try
the report in a separate 3.7.2 install to see if the issue has been
fixed in a later version of BIRT. You may want to look over these bugs:
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advanced;short_desc=word%20font;short_desc_type=allwordssubstr;product=BIRT;classification=BIRT
Jason
On 6/6/2012 11:46 PM, Missing name Mising name wrote:
> I can't Jason because system in which I am importing does not support on
> example 3.7 Birt reports.I already tried.
> fontsConfig_PDF is file for changing fonts for PDF but which file is for
> WORD.
> Firstly I didn't change it to Arial Unicode and then I could open my
> document but all letters except for English ones, was displayed as
> little squares.
> Does for correct Word format it is only enough to change
> fontConfig_linux? Why when I changed this to Arial_Unicode my PDF file
> also can not be opened? Like the change in this file also effects and
> PDF export which I finally managed to set. But how then to set font for
> correct WORD document? It is not problem on the WORD side because when I
> select text and change it manually in Arial Unicode WORD everything is OK.
> If fontConfig linux is not supposed to be changed where then I have tto
> change this to some format other from Lucida for WORD?
> Do I have some alternative?
> Thanks
Re: Export to DOC Microsoft Word Issue [message #884650 is a reply to message #883112] |
Mon, 11 June 2012 14:58 |
Member |
Unfortunately I can't test it in 3.7.2 because this IBM application does not support BIRT reports in this format.
Some guy wrote for his similar problem:
"Fixed.
Word can shift to the proper font if the user defined font can not display some
characters of a string. So we need not use the font-config. We just need to
handle the generic font mapping to make sure it is consonant with HTML and pdf
output."
But my does not shift to proper font? I saw that for all problem patches did not work.
Some othe guy wrote:
"Fixed. In word tag sz only applies for Asian and Latin fonts in a run. Add a
tag sz-cs to support complex script fonts in a run. "
Where to add this tags if this i solution?
Jason I think solution is to find where does BIRT or my application sets this Lucida font for default word export. I found it only in fontsConfig_linux. There must be some other place also what do you think? thanks
[Updated on: Mon, 11 June 2012 15:01] Report message to a moderator
Re: Export to DOC Microsoft Word Issue [message #884732 is a reply to message #884650] |
Mon, 11 June 2012 17:31 |
I believe the sz-cs is in the word xml format. You may want to open a
bugzilla entry to see if any of the devs have a possible work around.
Jason
> "Fixed.
> display some
> and pdf
> output."
> did not work.
> Add a
FUDForum. Page generated in 0.04908 seconds
