Re: Activities do not hide BIRT views [message #881959 is a reply to message #881233] |
Tue, 05 June 2012 14:44 |
If you specify a pattern of one of the views completely (Without using
a regular expression) does it work? I wonder if it is conflicting with
the activities extension point that is in the org.eclipse.birt plugin.
Jason
On 6/4/2012 3:35 AM, Timothy Vogel wrote:
> Below is the activities extension in my plugin.xml from an RCP
> application. I am able to successfully hide views in my plugin and views
> contributed from various eclipse plugins. However the views from BIRT
> (at the bottom) have resisted my attempts to hide.
> Any suggestions on what I am doing wrong would be greatly appreciated.
> <extension
> point="org.eclipse.ui.activities">
> <activity
> id="base.contributedViews"
> name="contributedViews">
> </activity>
> <activityPatternBinding
> activityId="base.contributedViews"
> isEqualityPattern="false"
> pattern="org\.eclipse\.ui\.views/.*ContentOutline.*">
> </activityPatternBinding>
> pattern="org\.eclipse\.gef/.*palette_view">
> pattern="org\.eclipse\.ui\.views/.*PropertySheet">
> pattern="org\.eclipse\.birt.*/.*View.*">
Re: Activities do not hide BIRT views [message #882590 is a reply to message #882389] |
Wed, 06 June 2012 19:52 |
Can you open a bugzilla request for this. Maybe someone on the dev team
will have an idea of how to work around this.
Jason
On 6/6/2012 7:21 AM, Timothy Vogel wrote:
> Jason,
> Thanks for your quick reply!
> Changed the BIRT pattern to below. The report designer view still shows
> in the list. Any suggestions for overriding the BIRT activities?
> activityId="com.easa.acmotor.base.contributedViews"
> isEqualityPattern="true"
> pattern="org.eclipse.birt.report.designer.ui.views/org.eclipse.birt.report.designer.ui.views.data.DataView">
FUDForum. Page generated in 0.02247 seconds
