Home » Eclipse Projects » Remote Application Platform (RAP) » Styling height of view tab folder
Re: Styling height of view tab folder [message #882071 is a reply to message #881231] |
Tue, 05 June 2012 19:09 |
Benjamin Wolff Messages: 136 Registered: July 2009 |
Hi Ivan,
thanks for your response.
I already tried to adjust the padding, without success. I attached two screenshots to clarify the problem. The first image shows the tabfolder bar without any changes to the theme. The second screenshot show the bar with the following settings:
CTabItem {
padding: 0;
TabItem {
padding: 0;
The padding left and right is influenced, but not the height. Even settings a specific "height" in the theme doesn't change anything. I also searched the RAP codebase for "setTabHeight", but could not identify a place which looks like it would set the height for these tabs. Also, I could not get a handle to the tab folder so set the height programmatically.
Do you maybe have any ideas?
Ben
Am 04.06.2012 09:29, schrieb Ivan Furnadjiev:
> Hi Ben,
> CTabFolder has a method setTabHeight that overrides the item height set by theming. If you want to adjust it through the theming decrease the CSS value for CTabItem#padding or TabItem#padding.
> HTH,
> Ivan
> On 6/3/2012 11:48 PM, Benjamin Wolff wrote:
>> Hi,
>> I have added some views to a perspective using an IFolderLayout. The views can be selected as tabs in a tabfolder. The tab-item headers have been increased in size in the latest default theme.
>> Can someone tell me how I can style the height of these tab-item headers? I tried styling TabItem and CTabItem, without success. I can style the padding left and right, but not the height.
>> Thank you!
>> Cheers,
>> Ben
Attachment: tab_bar1.png
(Size: 2.99KB, Downloaded 218 times) -
Attachment: tab_bar2.png
(Size: 3.17KB, Downloaded 180 times)
Re: Styling height of view tab folder [message #882093 is a reply to message #882071] |
Tue, 05 June 2012 20:44 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Ben,
the ViewPart height is set by the workbench - see DefaultTabFolder line
178 and DefaultTabFolder#computeTabHeight.
HTH,
Ivan
On 6/5/2012 10:09 PM, Benjamin Wolff wrote:
> Hi Ivan,
> CTabItem {
> padding: 0;
> TabItem {
> padding: 0;
> Cheers,
> Ben
>> Hi Ben,
>> HTH,
>> Ivan
>>> Hi,
>>> Thank you!
>>> Cheers,
>>> Ben
Ivan Furnadjiev
Twitter: @EclipseRAP
Current Time: Thu Apr 25 11:23:20 GMT 2024
Powered by FUDForum. Page generated in 0.04928 seconds
