Home » Archived » EGL Development Tools » Error when connecting to IBM i(An exception occured during a service call)
Error when connecting to IBM i [message #879553] Thu, 31 May 2012 08:17 Go to next message
I'm trying to follow the example in the video of connecting to an IBMi, I'm getting an error:An exception occured during a service call. Service:server.CallRpgService, Function:server.CallRpgService
I don't see any messages generated on the IBMi. My code seems to match the example that worked. Not sure where to look next to resolve it.
Server code is below:
package server;
// service
service CallRpgService
function hello (name string inout)
	@IBMiProgram {
	  programName = "MYRPG",
	  libraryName = "/QSYS.LIB/BWEEKS.LIB/",
	  parameterAnnotations = [ @AS400Text { length = 40}
	  	connectionResourceBindingURI = "binding:MyConnection"
end
end
client code below:
package client;
// RUI Handler
import org.eclipse.edt.rui.widgets.GridLayout;
import org.eclipse.edt.rui.widgets.TextLabel;
import org.eclipse.edt.rui.widgets.GridLayoutData;
import org.eclipse.edt.rui.widgets.TextField;
import org.eclipse.edt.rui.widgets.Button;
import server.*;
handler CallRPGClient type RUIhandler{initialUI =[ui
            ], onConstructionFunction = start, cssFile = "css/MyIBM2.css", title = ""}
    ui GridLayout{columns = 3, rows = 4, cellPadding = 4, children = [ varButton2, varErrorLabel, varButton, varNameField, varNameLabel ]};
    varNameLabel TextLabel{ layoutData = new GridLayoutData{ row = 1, column = 1 }, text = "Name" };
    varNameField TextField{ layoutData = new GridLayoutData{ row = 1, column = 2 }};
    varButton Button{ layoutData = new GridLayoutData{ row = 3, column = 2 }, text = "Go!", onClick ::= varButton_onClick };
    varErrorLabel TextLabel{ layoutData = new GridLayoutData{ row = 4, column = 2 }, text = " " };
    varButton2 Button{ layoutData = new GridLayoutData{ row = 3, column = 3 }, text = "Clear", onClick ::= varButton2_onClick };
    function start()
    end
    function varButton_onClick(event Event in)
    	call CallRpgService.hello(varNameField.text)
    		using new HttpProxy
    		returning to myCallbackFunction
    		onException myExceptionHandler;
    end
   function myCallbackFunction( name string in)
     varNameField.text = name;
   end
   function myExceptionHandler( exp AnyException in);
    varErrorLabel.text = exp.message;
  end
   function varButton2_onClick(event Event in)
   	varErrorLabel.text = "";
   	varNameField.text = "";
   end
end
Re: Error when connecting to IBM i [message #879657 is a reply to message #879553] Thu, 31 May 2012 11:39 Go to previous messageGo to next message
The message details may help resolve the problem. Change your exception handler to include the details:
    SysLib.writeStdOut(exp.message);
    if(exp isa ServiceInvocationException)
      SysLib.writeStdOut("Detail1:" + (exp as ServiceInvocationException).detail1);
      SysLib.writeStdOut("Detail2:" + (exp as ServiceInvocationException).detail2);
      SysLib.writeStdOut("Detail3:" + (exp as ServiceInvocationException).detail3);
    end
  end
If this does not provide additional information about the exception, create a new service function hello2 and call it from the client. The new function will catch the exception and print the exception in the server console.
function hello2 (name string inout)
  try
    call hello(name);
  onexception(exp anyexcption)
  end
end
regards,
Joe
Re: Error when connecting to IBM i [message #879680 is a reply to message #879657] Thu, 31 May 2012 12:18 Go to previous message
THANKS !
That gave me the additional info I was missing.
The issue was that I renamed the project, and the deployment descriptor still had the previous name. The additional error message told me I didn't have default deployment descriptor.
Thanks again.
B.
Previous Topic:Error when opening 'HelloWorldView.egl'
Next Topic:Gridlayout in datagrid
Current Time: Tue Jul 15 07:45:42 EDT 2025
Powered by FUDForum. Page generated in 0.27765 seconds
