Home » Eclipse Projects » BIRT » How to get the absolute location of a data source
How to get the absolute location of a data source [message #879288] Wed, 30 May 2012 23:15 Go to next message
Neil Wang is currently offline Neil WangFriend
I am trying to get the absolute location of a data source programmatically and this is what I have done so far:
I have a ReportDesignHandle object "rdh" and used rdh.getAllDataSources() to cast all data sources to a list of DesignElementHandle objects.
I further cast each DesignElementHandle object to an OdaDataSourceHandle object.
I checked all the methods of each object at the ReportDesignHandle, DesignElementHandle and OdaDataSourceHandle level but still can't figure out how to get the absolute location of each data source. Please advise.
Neil
Re: How to get the absolute location of a data source [message #879295 is a reply to message #879288] Wed, 30 May 2012 23:29 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Neil,,
Do you mean like position on the report? Datasets do not have a
location. Tables do but unless you specify a width/height you I do not
believe we expose generated position.
Jason
On 5/30/2012 7:15 PM, Neil Wang wrote:
> object.
> Neil
Re: How to get the absolute location of a data source [message #879297 is a reply to message #879295] Wed, 30 May 2012 23:36 Go to previous messageGo to next message
Hi Jason,
Sorry, I should've been clearer. I am looking for the absolute path of each data source in the file system.
Neil
Re: How to get the absolute location of a data source [message #879320 is a reply to message #879297] Thu, 31 May 2012 00:58 Go to previous messageGo to next message
What kind of data source is it?
Jason
On 5/30/2012 7:36 PM, Neil Wang wrote:
> Hi Jason,
> Neil
Re: How to get the absolute location of a data source [message #879694 is a reply to message #879320] Thu, 31 May 2012 16:57 Go to previous messageGo to next message
Hi Jason,
The source is a XML file.
Please have a look at the screen shot in attachment. Basically, I need to get "C:\Project1\NewMapping.xml" programmatically by using Java code.
Neil
  • Attachment: XML.JPG
    (Size: 31.78KB, Downloaded 125 times)
Re: How to get the absolute location of a data source [message #879793 is a reply to message #879694] Thu, 31 May 2012 21:19 Go to previous message
Neil,
You can try something like this:
reportContext.getDesignHandle().getDataSources().get(0).getProperty("FILELIST");
But if the connection profile changes at runtime I am not sure this will
be updated. BTW the profile location property is:
OdaConnProfileStorePath
Jason
On 5/31/2012 12:57 PM, Neil Wang wrote:
> Hi Jason,
> Neil
Previous Topic:Question on BIRT 3.7.2 export PDF
Next Topic:How to avoid ReferenceError error messages?
Current Time: Sat Oct 31 11:12:37 GMT 2020
Powered by FUDForum. Page generated in 0.02261 seconds
