Home » Modeling » M2T (model-to-text transformation) » [Acceleo] generation exception after deploy
[Acceleo] generation exception after deploy [message #878415] Tue, 29 May 2012 09:02 Go to next message
Vlad Gheorghe is currently offline Vlad GheorgheFriend
Hello all,
I have an Acceleo transformation which works fine when invoked from the target platform launched from Eclipse (PDE launch configuration).
When I try to deploy the jars of the same plug-ins I get the following exception:
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoS
ervice.java:565)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(
AbstractAcceleoGenerator.java:193)
at com.thalesgroup.dts.l905.dti.export.ui.ControlUnitGenerator$1.run(Con
trolUnitGenerator.java:45)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(Modal
Context.java:121)
It seems that the template files do not get loaded properly - that line accesses the type of a parameter of the main template - which is a class defined by my own ecore model.
I've checked and all plugins seem to be resolved.
Has anyone had this problem before ? What could be wrong ?
How can I further diagnose this problem ?
Any help would be greatly appreciated.
I use acceleo 3.2.0 / Indigo SR1.
Vlad Gheorghe
Re: [Acceleo] generation exception after deploy [message #878532 is a reply to message #878415] Tue, 29 May 2012 13:41 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Since there is a known issue with the compilation in Acceleo 3.2.0, I would first of all advise you to try with Acceleo 3.2.1: http://download.eclipse.org/modeling/m2t/acceleo/updates/releases/3.2
Then, check if the compiled modules are in your jar (.emtl files).
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo] [SOLVED] generation exception after deploy [message #879143 is a reply to message #878415] Wed, 30 May 2012 15:42 Go to previous messageGo to next message
Hi Stephane,
Thanks for the suggestion !
After upgrade to indigo SR2 + Acceleo 3.2.1 it worked.
Just a clarification :
Which is the Acceleo version delivered with the indigo SR2 (3.7.2) simultaneous update ?
It doesn't seem one can get acceleo 3.2.1 from the indigo update site.
Thanks again !
Vlad
Re: [Acceleo] [SOLVED] generation exception after deploy [message #885106 is a reply to message #879143] Tue, 12 June 2012 13:25 Go to previous messageGo to next message
Eclipse 3.6.x Helios -> Acceleo 3.0.x
Eclipse 3.7.x Indigo -> Acceleo 3.1.x
Eclipse 3.8.x / 4.2.x Juno -> Acceleo 3.3.x
Acceleo 3.2.x was released outside of the regular Eclipse release train since we did not want to wait one year to ship new features. It is only available thanks to the Acceleo update sites. Being on the release train, we have to release something along with each new release of Eclipse but we can also have some releases outside of the regular Eclipse lifecycle.
Re: [Acceleo] [SOLVED] generation exception after deploy [message #983841 is a reply to message #885106] Wed, 14 November 2012 07:27 Go to previous message
Missing name Missing name is currently offline Missing name Missing nameFriend
Is it fixed in 3.3. I see this error in eclipse3.8+acceleo3.3
Previous Topic:[Xpand] model Root
Next Topic:[Acceleo] Problem xmi reference to another xmi
Current Time: Mon Aug 08 14:28:51 GMT 2022
Powered by FUDForum. Page generated in 0.01593 seconds
