Import an external library to RAP-project using ServletBridge [message #115550] |
Fri, 12 December 2008 16:33 |
Alex Messages: 6 Registered: July 2009 |
I'm looking for a solution to this problem for several days. I want to
deploy my RAP app on an external server (Tomcat 5.5). As far as I don't
need some external libraries this works fine using the equinox servlet
bridge.
I need to communicate with an instance of the quartz scheduler, but in my
RAP-Application the import failed. Maybe some dependencies missing, so I
implemented a minimal class, that has no more dependencies, and packed it
into a jar (test.jar). This I've included in my RAP-Application
(WEB-INF/lib, classpath is valid) and deployed my project on the server as
usual. Invoking the project in the browser causes the exception beneath.
The test.jar you can find in the plug-in-jar of my project, RAP_1.0.0.jar
(jakarta-tomcat-5.5.9\webapps\myproj\WEB-INF\eclipse\plugins ). Any other
possible locations I have already tried, just like the configuration
properties, that seemed logic to me. Is there anything I did not see or
doesn't it even work that way? Thanks for your support and please excuse
my newbie question.
java.lang.RuntimeException: java.lang.Error: Unresolved compilation
problem:
The import org.test cannot be resolved
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.handleUIThre adException(RWTLifeCycle.java:291)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.executeUIThr ead(RWTLifeCycle.java:271)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:154)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$1.r un(LifeCycleServiceHandler.java:60)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:176)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:168)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:133)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:45 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:33)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:140)
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:100)
org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:51)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.servletbridge.BridgeServlet.service(Brid geServlet.java:115)
Re: Import an external library to RAP-project using ServletBridge [message #115588 is a reply to message #115550] |
Fri, 12 December 2008 19:49 |
Neil Bartlett Messages: 93 Registered: July 2009 |
Member |
Hello Alex,
Have you tried wrapping the library you want to use as a plug-in (using
PDE's "Plug-in from existing JAR archives" wizard) and including it with
the RAP application?
Neil
Alex wrote:
> bridge.
> (jakarta-tomcat-5.5.9webappsmyprojWEB-INFeclipseplugins). Any other
> my newbie question.
> problem:
Re: Import an external library to RAP-project using ServletBridge [message #115720 is a reply to message #115708] |
Mon, 15 December 2008 10:05 |
Alex wrote:
> Hmm, next step: I added the created TestPlugin as a "Required Plug-in"
> in the Dependencies-menu of the build-properties. After doing that I got
> this exception, although I haven't changed anything in the
> entrypoint-configuration:
> java.lang.IllegalArgumentException: An entry point named 'default' does
> not exist.
> org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:77)
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
> org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
> java.lang.Thread.run(Thread.java:619)
This is usually a follow-up error. The entry point does not exist
because the bundle is not resolved, because ...
Sure you added the required new bundle in your launch config?
Regards, Ralf
FUDForum. Page generated in 0.03321 seconds
