Home » Archived » Test and Performance Tools Platform (TPTP) » Generating test reports
Generating test reports [message #115392] Sun, 14 October 2007 18:57 Go to next message
Dimiter Dimitrov is currently offline Dimiter DimitrovFriend
I’m following documentation from the help of TPTP. My work environment
includes platform + test environment. I want to generate test report, as
it is described here (the link is relevant to my installation of course):
http://127.0.0.1:51030/help/topic/org.eclipse.hyades.test.do c.user/tasks/tcreatetestreports.htm
Unfortunately, when I select context menu of the test, the “Report...”
action is not provided in the pop-up menu. Could you suggest me where I’m
wrong? As I saw from the instruction this report is not BIRT report, so I
don’t need BIRT feature?
Dimiter
Re: Generating test reports [message #115445 is a reply to message #115392] Mon, 15 October 2007 09:31 Go to previous messageGo to next message
Originally posted by: matthias.goettler.mathema.de
Hi Dimiter,
I have the same problem. I already tried to add the BIRT libraries (from
the TPTP-download page), but that did not work either.
Hope there are better guesses available... :-)
Bye
Matthias
Re: Generating test reports [message #115468 is a reply to message #115392] Mon, 15 October 2007 10:20 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Dimiter,
You have to be in the Test Navigator of the Test Perspective to see the
Report context menu.
Also, you will need the BIRT, GMF, and DTP dependencies if you want to
use the BIRT test reports:
http://www.eclipse.org/tptp/home/downloads/
Paul
"Dimiter Dimitrov" <d.dimitrov@sap.com> wrote in message
news:f850c2f1fea2ed1e49d77d884908801e$1@www.eclipse.org...
> Hello,
> I
Re: Generating test reports [message #115481 is a reply to message #115445] Mon, 15 October 2007 10:21 Go to previous messageGo to next message
Hi Matthias,
You also will need the GMF, and DTP dependencies if you are using TPTP
4.4.x. Also, make sure you are in the Test Navigator of the Test
Perspective to see the Report context menu.
Paul
"Matthias Goettler" <matthias.goettler@mathema.de> wrote in message
news:9537f3858a2200f2caaae36ac7781cd9$1@www.eclipse.org...
> Hi Dimiter,
> Bye
> Matthias
Re: Generating test reports [message #115493 is a reply to message #115481] Mon, 15 October 2007 11:30 Go to previous messageGo to next message
Hi Paul,
thank you for your answer.
Does this requirement for BIRT, GMF and DTP also apply for the test report
generation via ASF (see my other posting from today) and ant?
Bye
Matthias
Re: Generating test reports [message #115738 is a reply to message #115493] Wed, 17 October 2007 12:05 Go to previous messageGo to next message
Yes.
news:3a5934f4438e6d7bc797b5a790f58e60$1@www.eclipse.org...
> Hi Paul,
> Bye
> Matthias
Re: Generating test reports [message #115896 is a reply to message #115738] Thu, 18 October 2007 06:53 Go to previous messageGo to next message
Once again, hello Paul,
I'm sorry, but simply adding the mentioned plugins to my eclipse
installation did not get me any further.
Although generating reports from the eclipse workbench does work now,
generating them from an ant script still is not possible. The errors are
described in my posting from the 15th Oct. titled "[asf]....". Probably,
there is once again something fundamental that I'm missing...
Bye
Matthias
Re: Generating test reports [message #117241 is a reply to message #115896] Tue, 06 November 2007 11:46 Go to previous message
Hi Matthias,
Good to hear that reporting is working in the UI. I will someone reply
to your Oct 15 post regarding the ASF.
Paul
news:df7c959f36ceec0195b18c65e6763670$1@www.eclipse.org...
> Bye
> Matthias
Previous Topic:Agent Controller is unavailable under port 10002
Next Topic:[AGR] Hang problem in AGR 4.4
Current Time: Fri May 14 16:52:40 GMT 2021
Powered by FUDForum. Page generated in 0.02644 seconds
