Home » Modeling » Epsilon » ETL: protected regions not working
ETL: protected regions not working [message #877041] |
Fri, 25 May 2012 19:10 |
I'm trying to use protected regions with ETL. So, I put the following code in the template:
[%=out.preserve("/*", "*/", name+"-Prop", true," //TODO")%]
This generates the following code:
/* protected region Local-Prop on begin */
//TODO
/* protected region Local-Prop end */
which I think is correct.
Then I changed the previous code to this:
test();
I was hopping that after generating the code again I was going to keep the 'test();', but that content is lost, and it is replaced with '//TODO'.
Am I doing anything wrong? Is there anything else I need to do, besides using the "preserve" method?
Re: ETL: protected regions not working [message #877108 is a reply to message #877041] |
Fri, 25 May 2012 22:18 |
That seems fine according to the book. In our case we use
[%=out.startPreserve("--", "--",entity.identifier + " Additional Descriptions", true)%]
[%=out.stopPreserve()%]
But I now recall I have a report of preserved regions being overwritten as in our case. Any one has any other ideas?
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
Re: ETL: protected regions not working [message #878479 is a reply to message #877775] |
Tue, 29 May 2012 12:01 |
Louis Rose Messages: 440 Registered: July 2009 Location: York, United Kingdom |
Hi Rui Carlos,
Rui Carlos Gonçalves wrote on Sun, 27 May 2012 13:55I've already tried many different ways (preserve/startPreserve, different ids, different comments ), and it's not working :\
I'm not using any special character in the id.
I'm sorry to hear that you're having problems with protected regions. I think this might be related to the bug that Martin mentions. Can you try again without the hyphen in the identifier? So, for example:
[%=out.preserve("/*", "*/", name+"Prop", true," //TODO")%]
I believe that, in the latest stable release of Epsilon, identifiers could only contain word characters (i.e. [a-zA-Z_0-9]). Alternatively, you can try updating to the latest interim release of Epsilon, which contains the fix for this bug and should work with your existing code.
Hope this helps,
Louis.
Re: ETL: protected regions not working [message #878567 is a reply to message #878479] |
Tue, 29 May 2012 14:38 |
Hi Louis. Thanks for your reply.
Louis Rose wrote on Tue, 29 May 2012 13:01I believe that, in the latest stable release of Epsilon, identifiers could only contain word characters (i.e. [a-zA-Z_0-9]). Alternatively, you can try updating to the latest interim release of Epsilon, which contains the fix for this bug and should work with your existing code.
No, I have already tried that...
Is there any debug mode that can me help finding the problem?
BTW, do I have to set any option in the run configuration to be able to use protected regions?
Re: ETL: protected regions not working [message #886913 is a reply to message #879016] |
Fri, 15 June 2012 20:33 |
I think I've solved the problem...
I was calling the template directly in a Run Configuration and it was not working.
Now I'm using "TemplateFactory.load"/"generate" methods instead of calling the template directly, and it seems to be working
Not sure if this is the expected behavior, but it solved the problem.
PS: Louis, if this is still a bug (i.e., if protected regions are supposed to work even without using the "TemplateFactory.load"/"generate"), let me know, and I'll create the bug report. (I haven't done it yet, as creating a minimal example, with metamodels and editor, takes some time :\ )
[Updated on: Fri, 15 June 2012 20:34] Report message to a moderator
Re: ETL: protected regions not working [message #1776341 is a reply to message #886913] |
Wed, 15 November 2017 13:23 |
Víctor López Messages: 22 Registered: June 2014 |
Hi all!,
is this issue solved?
I'm using latest interim version of Epsilon in Oxygen.
I use the sample code from the book:
// protected region anId on begin
System.out.println(foo);
// protected region anId end
If I use that code directly it doesn't work.
If I create a EGL file and called it with generate works on the new target specified in the generate method.
If I use process it doesn't work.
Are there any requirements for preserved regions to work?
Best,
Víctor
[Updated on: Wed, 15 November 2017 13:24] Report message to a moderator
Current Time: Sat Apr 20 03:35:27 GMT 2024
Powered by FUDForum. Page generated in 0.03772 seconds
