Eclipse Dali generate entities from tables problem [message #876783] |
Fri, 25 May 2012 09:25 |
Balint Herczeg Messages: 1 Registered: May 2012 |
So in this example, there are 2 tables :
table people:
code: int
Id and code are both unique and primary keys.
table something:
peopleCode: int
In this table id and peopleCode are both primary keys, of course there is no good reason why peopleCode is primary key, it's not a well-designed database, and it has never been used with JPA, but I have to use this old database for a new project.
The two tables are in one to many relation with code-peopleCode, one 'people' has many 'something'. There is no foreign key constraint anyway.
I tried to generate entities from these tables with Eclipse Dali, I added the associations in the wizard, but I got the following error message, and table 'something' hadn't been generated:
org.eclipse.core.runtime.CoreException: Unable to find JPA entities generation templates in pluginorg.eclipse.jpt.jpa.gen
at org.eclipse.jpt.jpa.gen.internal.PackageGenerator.generateClass(PackageGenerator.java:245)
at org.eclipse.jpt.jpa.gen.internal.PackageGenerator.generateInternal(PackageGenerator.java:112)
at org.eclipse.jpt.jpa.gen.internal.PackageGenerator.doGenerate(PackageGenerator.java:90)
at org.eclipse.jpt.jpa.gen.internal.PackageGenerator.generate(PackageGenerator.java:67)
at org.eclipse.jpt.jpa.ui.internal.wizards.gen.GenerateEntitiesFromSchemaWizard$GenerateEntitiesJob.runInWorkspace(GenerateEntitiesFromSchemaWizard.java:248)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.apache.velocity.exception.MethodInvocationException: Invocation of method 'convertToJavaStringLiteral' in class org.eclipse.jpt.jpa.gen.internal.BaseEntityGenCustomizer threw exception java.lang.NullPointerException @ join.vm[58,44]
at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:286)
at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:203)
at org.apache.velocity.runtime.parser.node.ASTReference.value(ASTReference.java:419)
at org.apache.velocity.runtime.parser.node.ASTExpression.value(ASTExpression.java:73)
at org.apache.velocity.runtime.parser.node.ASTSetDirective.render(ASTSetDirective.java:125)
at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:74)
at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:88)
at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:318)
at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:107)
FUDForum. Page generated in 0.03286 seconds
