Home » Modeling » TMF (Xtext) » Cross-Reference
Cross-Reference [message #876403] Thu, 24 May 2012 14:27 Go to next message
Hans-Georg Glöckler is currently offline Hans-Georg GlöcklerFriend
Member
Hello;
I have a problem with Cross-Reference & XBase
The following Code is not working at:
Entity:
'entity' name=EntityName ('extends' superType=[Entity])? '{'
	features+=Feature*
and
Reference:
type=[Entity] name=ID ';';
The whole code of the project is:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.xbase.Xbase
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	elements+=AbstractElement*;
AbstractElement:
	Package | Import | Entity;
Package:
	'package' name=QualifiedName ';';
Import:
	'import' name=QualifiedNameWithWildCard ';';
Entity:
		features+=Feature*
Feature:
	Attribut | Reference;
Attribut:
	datatype=Datatype name=ID ';';
Reference:
enum Datatype:
	String | Integer | Double | TimeStamp | Text | Char;
terminal EntityName:
	('A'..'Z' | '_') ('a'..'z' | 'A'..'Z' | '_' | '0'..'9')*;
QualifiedNameWithWildCard:
	QualifiedName '.*'?;
Code of my DSL is
package org.demo01;
import org.demo.*;
entity Klaus {
	String akke;
entity Alfred {
	String alfred;
I can not write :
entity Alfred extends Klaus {
	String alfred;
I can not write :
entity Alfred {
	String alfred;
        Klaus klaus;
What is wrong in my DSL
Re: Cross-Reference [message #876492 is a reply to message #876403] Thu, 24 May 2012 18:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
why do you inherit from Xbase if you do not use it?
the actual problem is:
EntityName hides ID
i would remove entityname and replace it with ID
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Cross-Reference [message #876714 is a reply to message #876492] Fri, 25 May 2012 07:11 Go to previous messageGo to next message
Member
I have changed it, but i still get an error.
mismatched input Klaus expecting RULE_ID.
Entity:
	'entity' name=ID ('extends' superType=[Entity])? '{'
		features+=Feature*
I use Xbase because this is not the whole code.
In other Code I have to use
Operation:
	visibility=Visibility? 'op' name=ValidID '(' (params+=JvmFormalParameter (',' params+=JvmFormalParameter)*)? ')' ':' type=JvmTypeReference
		body=XBlockExpression;
Re: Cross-Reference [message #876717 is a reply to message #876714] Fri, 25 May 2012 07:16 Go to previous messageGo to next message
Please Post a complete reproduceable grammar
Re: Cross-Reference [message #876725 is a reply to message #876717] Fri, 25 May 2012 07:44 Go to previous messageGo to next message
Member
Model:
AbstractElement:
Package:
Import:
Entity:
		features+=Feature*
Feature:
Attribut:
Reference:
	'Ref' type=[Entity] '[0..1]' name=ValidID ';';
enum Datatype:
Re: Cross-Reference [message #876734 is a reply to message #876725] Fri, 25 May 2012 07:55 Go to previous messageGo to next message
Hi delete this entityname crap
Re: Cross-Reference [message #876756 is a reply to message #876734] Fri, 25 May 2012 08:41 Go to previous messageGo to next message
Member
thanks, now it works
One more question:
How can i define, that an Entity can not begin with a number?
For example:
terminal ID:
('A'..'Z' | 'a'..'z' | '_')*;
Re: Cross-Reference [message #876760 is a reply to message #876756] Fri, 25 May 2012 08:46 Go to previous messageGo to next message
and ID already cannt begin with a number can it? (see Terminals Supergrammar)
~Christian
Re: Cross-Reference [message #876765 is a reply to message #876760] Fri, 25 May 2012 08:51 Go to previous messageGo to next message
Member
thanks
very good
One more last Question:
I want to write the following Code
Mensch [0..1] mensch;
My Grammar is
Reference:
	type=[Entity] refEnum=RefEnum name=ValidID ';';
enum RefEnum:
	[1..1], [1..*], [*..1], [*..*];
How must I write:
Re: Cross-Reference [message #876786 is a reply to message #876765] Fri, 25 May 2012 09:26 Go to previous messageGo to next message
hi,
have a look at the docs
enum RefEnum:
onetoone="[1..1]"| oneton="[1..*]"| ntoone="[*..1]"| nton="[*..*]";
Re: Cross-Reference [message #876800 is a reply to message #876786] Fri, 25 May 2012 09:53 Go to previous messageGo to next message
Member
Thanks.
I have solved it the following way
Model:
AbstractElement:
Package:
Import:
Entity:
	features+=Feature*
Feature:
Attribut:
Reference:
	(containment=Containment)? type=[Entity] '[' lowerBound=BoundLiteral '..' upperBound=BoundLiteral ']' name=ValidID
//enum RefEnum:
//	ONE_TO_ONE='[1..1]' | ONE_TO_MANY='[1..*]' | MANY_TO_ONE='[*..1]' | MANY_TO_MANY='[*..*]';
enum BoundLiteral:
	ONE='1' | MANY='*';
enum Containment:
	contains;
enum Datatype:
But now I have the problem, that the CodeAssist don't work with
Reference:
Re: Cross-Reference [message #876804 is a reply to message #876800] Fri, 25 May 2012 09:57 Go to previous messageGo to next message
what do you mean with "the CodeAssist don't work with"
Re: Cross-Reference [message #876815 is a reply to message #876804] Fri, 25 May 2012 10:11 Go to previous messageGo to next message
Member
When I use the DSL
package org.demo;
import org.demo01.*;
entity Customer {
	String test;
entity Item {
entity Order {
	Customer [1..*] customer;
	contains Detail [1..*] details;
entity Detail {
	Item [1..1] item;
Here all is ok, but for following the CodeAssist don't work
=> here especialy for [1..*]
Code Assit = <Ctrl> + <Leertaste>
[Updated on: Fri, 25 May 2012 10:12]
Report message to a moderator
Re: Cross-Reference [message #876836 is a reply to message #876815] Fri, 25 May 2012 11:10 Go to previous messageGo to next message
you have to override isKeywordWorthyToPropose in the proposalprovider (you are the guy using Xbase Wink)
~Christian
Re: Cross-Reference [message #876864 is a reply to message #876836] Fri, 25 May 2012 12:10 Go to previous message
Member
Thanks, all ok.
Previous Topic:[Xtend 2.3 M6] Function1 cannot be used as parameter
Next Topic:Possible leak in SortOutlineContribution
Current Time: Sat Jan 16 04:11:44 GMT 2021
Powered by FUDForum. Page generated in 0.02485 seconds
