Home » Eclipse Projects » BPMN 2.0 Modeler » Problems opening a BPMN flow
Problems opening a BPMN flow [message #876246] Thu, 24 May 2012 08:27 Go to next message
Guido Zerbinati is currently offline Guido ZerbinatiFriend
Hi, I have some problems using the BPMN2.0 Modeler (Indigo) on the JPBM 5.3 FULL installer demo.
I've downloaded and installed everythng but when I try to open a diagram I receive this exception:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.bpmn2.modeler.ui (390).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.core.internal.content.ContentType.getDescriber(ContentType.java:271)
at org.eclipse.core.internal.content.ContentType.internalGetDescriptionFor(ContentType.java:450)
at org.eclipse.core.internal.content.ContentTypeCatalog.getDescriptionFor(ContentTypeCatalog.java:356)
at org.eclipse.core.internal.content.ContentTypeCatalog.getDescriptionFor(ContentTypeCatalog.java:360)
at org.eclipse.core.internal.content.ContentTypeMatcher.getDescriptionFor(ContentTypeMatcher.java:86)
at org.eclipse.core.internal.resources.ContentDescriptionManager.readDescription(ContentDescriptionManager.java:445)
at org.eclipse.core.internal.resources.ContentDescriptionManager.getDescriptionFor(ContentDescriptionManager.java:355)
at org.eclipse.core.internal.resources.File.getContentDescription(File.java:271)
at org.eclipse.wst.sse.core.internal.propertytester.StructuredFilePropertyTester.testContentType(StructuredFilePropertyTester.java:68)
at org.eclipse.wst.sse.core.internal.propertytester.StructuredFilePropertyTester.test(StructuredFilePropertyTester.java:45)
at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:99)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:53)
at org.eclipse.core.internal.expressions.AdaptExpression.evaluate(AdaptExpression.java:91)
at org.eclipse.core.internal.expressions.IterateExpression.evaluate(IterateExpression.java:150)
at org.eclipse.core.internal.expressions.CompositeExpression.evaluateOr(CompositeExpression.java:68)
at org.eclipse.core.internal.expressions.OrExpression.evaluate(OrExpression.java:21)
at org.eclipse.core.internal.expressions.ReferenceExpression.evaluate(ReferenceExpression.java:70)
at org.eclipse.ui.internal.services.EvaluationResultCache.evaluate(EvaluationResultCache.java:74)
at org.eclipse.ui.internal.services.ExpressionAuthority.evaluate(ExpressionAuthority.java:165)
at org.eclipse.ui.internal.services.EvaluationAuthority.refsWithSameExpression(EvaluationAuthority.java:155)
at org.eclipse.ui.internal.services.EvaluationAuthority.sourceChanged(EvaluationAuthority.java:129)
at org.eclipse.ui.internal.services.ExpressionAuthority.sourceChanged(ExpressionAuthority.java:311)
at org.eclipse.ui.internal.services.ExpressionAuthority.sourceChanged(ExpressionAuthority.java:302)
at org.eclipse.ui.AbstractSourceProvider.fireSourceChanged(AbstractSourceProvider.java:80)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.selectionChanged(WorkbenchSourceProvider.java:177)
at org.eclipse.ui.internal.AbstractSelectionService.fireSelection(AbstractSelectionService.java:156)
at org.eclipse.ui.internal.AbstractSelectionService$1.selectionChanged(AbstractSelectionService.java:62)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:164)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:162)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2188)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1211)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1241)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:239)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:233)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:403)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.bpmn2.modeler.ui.Activator for bundle org.eclipse.bpmn2.modeler.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:171)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 79 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/bpmn2/modeler/core/adapters/AdapterRegistry
at org.eclipse.bpmn2.modeler.ui.Activator.<clinit>(Activator.java:66)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:166)
... 85 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.bpmn2.modeler.core (388).
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
... 93 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.bpmn2.modeler.core.Activator.start() of bundle org.eclipse.bpmn2.modeler.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
... 102 more
at org.eclipse.bpmn2.modeler.core.preferences.Bpmn2Preferences.getActiveProject(Bpmn2Preferences.java:837)
at org.eclipse.bpmn2.modeler.core.preferences.Bpmn2Preferences.getInstance(Bpmn2Preferences.java:148)
at org.eclipse.bpmn2.modeler.core.Activator.start(Activator.java:50)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 108 more
This error doesn't appear if I work on Eclipse without JBPM Demo running. Maybe some Eclipse configuration done by the demo startup configuration.
in the biuld.xml file eclipse start up with this conf:
<exec executable="${eclipse.home}/eclipse.exe"
spawn="yes"
osfamily="windows">
<arg value="-data" />
<arg value="${eclipse.workspace.dir}" />
<arg value="-plugincustomization" />
<arg value="./eclipse.preferences.ini" />
<arg value="-perspective" />
<arg value="org.jbpm.eclipse.JBPMPerspective" />
</exec>
Eclipse.preferences.ini has this line only: "org.jbpm.eclipse/jBPM.Runtimes=jBPM runtime#./runtime#true# "
Any suggestion?
Thanks a lot
G.
[Updated on: Thu, 24 May 2012 08:53]
Report message to a moderator
Re: Problems opening a BPMN flow [message #879138 is a reply to message #876246] Wed, 30 May 2012 15:29 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
Hi Guido,
I think this was reported here: by https://bugs.eclipse.org/bugs/show_bug.cgi?id=379741
Can you please try a more recent build and see if the problem goes away?
Thanks!
Bob
Re: Problems opening a BPMN flow [message #881516 is a reply to message #879138] Mon, 04 June 2012 18:25 Go to previous message
Markus Thies is currently offline Markus ThiesFriend
Had the same exception and problem. I had it on Windows 7 PC.
The problems seems to be related with the Administrator rights. You have to start Eclipse once with "Run as administrator" and create a BPMN Model / diagram. After the initial load/install of some additional features/plug-ins, it works fine the next time without having to start with Admin rights.
At least on my PC it did help.
Previous Topic:Importing BPMN 2.0 models from other tools
Next Topic:ServiceTask and WSDL
Current Time: Tue Apr 16 15:34:39 GMT 2024
Powered by FUDForum. Page generated in 0.16616 seconds
