Hudson looses all history [message #875882] |
Wed, 23 May 2012 13:48 |
maarten meijer Messages: 146 Registered: July 2009 |
after the split I stayed with Jenkins, but after Hudson moved to
Eclipse.org I reverted back to Hudson. My problem is as follows:
I'm using an ANT build, and the problem only occurs with ANT builds.
In the dashboard the build history is built up from the build.xml files
that are stored in each of the job folders.
When build.xml is gone, nothing is displayed.
Since some time, my hudson no longer creates such a build.xml files
after a build.
So history is shown only till hudson is restarted at some point.
Why is build.xml no longer generated?
I also have to newer maven builds and they work as before.
Hudson version 2.2.0
FUDForum. Page generated in 0.02765 seconds
