Re: Changing date format of DateTime widget [message #115076 is a reply to message #115039] |
Tue, 09 December 2008 15:17 |
Originally posted by: ifurnadjiev.innoopract.com
Hi Setya,
the format of date in DateTime widget depends on client (browser) locale
(language). If the browser content language is en-US the format will be
MM/dd/yyyy, but if it is German (de-de) for example, the format will be
dd/MM/yyyy. To check this you can set in Firefox your preferred language
in Options -> Content -> Languages and see the result. Anyway, there is
no explicitly way to set to format if DateTime widget. This is the same
in SWT.
Best,
Ivan
Setya wrote:
> Is it possible to change the date format in DateTime Widget ? When I
> first try it, the format is MM/dd/yyyy, I want to change it into
> dd/MM/yyyy.
> Regards,
> Setya
Re: Changing date format of DateTime widget [message #115100 is a reply to message #115039] |
Tue, 09 December 2008 15:52 |
Originally posted by: rherrmann.innoopract.com
Use RWT#getLocale() to query the currently used locale and
RWT#setLocale() to alter it.
The date time widget uses this information to display date and time
information.
HTH
Rüdiger
Setya wrote:
> dd/MM/yyyy.
> Regards,
> Setya
FUDForum. Page generated in 0.02780 seconds
