Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo API specification online?
Teneo API specification online? [message #114958] Mon, 17 March 2008 18:03 Go to next message
Originally posted by: schlamp.medihack.org
Is there an API specification (Javadoc) of Teneo online? I searched
elver.org and eclipse.org, but didn't find one. Did I miss something?
Kai
Re: Teneo API specification online? [message #114984 is a reply to message #114958] Mon, 17 March 2008 18:22 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Kai,
No not really, you should get the source code (is installed automatically as part of the sdk), the
source code contains comments were appropriate.
gr. Martin
> Kai
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo API specification online? [message #115063 is a reply to message #114984] Tue, 18 March 2008 19:33 Go to previous messageGo to next message
Thanks for the answer, Martin. And also thanks for such a nice peace of
software. Teneo is great.
I will generate the Javadoc myself, but I think an online API reference on
your website, or an integrated one in the help system after installing the
plugin would help a lot. Me and a lot of other developers I know, like to
look at the API before installing anything to get an overview.
Kai
Martin Taal wrote:
> Hi Kai,
> gr. Martin
>> Kai
Re: Teneo API specification online? [message #115075 is a reply to message #115063] Tue, 18 March 2008 19:50 Go to previous messageGo to next message
Hi Kai,
I understand what you mean but just to explain why I am not that javadoc focused (and why I am
afraid that the generated javadoc won't look that nice). One reason is ofcourse time... (it always
is), it is a fair amount of work to keep the javadoc in sync with the code. So therefore in the past
years I have moved away from doing javadoc. Comments in the code are easier to maintain and this
together with the code should be readable enough.
Also eclipse makes it very easy to step through the code. I have worked a lot with hibernate (which
almost has no javadoc) and I did not feel that as an obstacle as I was stepping through the code.
And as a last reason for not having a good javadoc around the api is that the api of Teneo should be
largely hidden for the user, there are the setEPackage, setProperties and the initialize methods of
the datastore and for the rest the user can talk to hibernate/emf.
Having said all this, nicely formatted javadoc (like the java sdk itself) can for sure be of help.
Like the javadoc with the java dateformat which has often saved me some time.
gr. Martin
> on your website, or an integrated one in the help system after
> installing the plugin would help a lot. Me and a lot of other developers
> I know, like to look at the API before installing anything to get an
> overview.
> Best regards,
> Kai
> Martin Taal wrote:
>> Hi Kai,
>> automatically as
>> gr. Martin
>>> Kai
The Netherlands
Re: Teneo API specification online? [message #115286 is a reply to message #115075] Fri, 21 March 2008 16:37 Go to previous message
Hi Martin,
thanks for the explanations and for the wonderful Teneo support here in
the newsgroup.
And you are right, the code is really good commented.
Kai
Martin Taal wrote:
> Hi Kai,
> gr. Martin
>> overview.
>> Best regards,
>> Kai
>> Martin Taal wrote:
>>> Hi Kai,
>>> automatically as
>>> gr. Martin
>>>> Kai
Re: Teneo API specification online? [message #615916 is a reply to message #114958] Mon, 17 March 2008 18:22 Go to previous message
Hi Kai,
gr. Martin
> Kai
The Netherlands
Re: Teneo API specification online? [message #615928 is a reply to message #114984] Tue, 18 March 2008 19:33 Go to previous message
Kai Schlamp is currently offline Kai SchlampFriend
Kai
Martin Taal wrote:
> Hi Kai,
> gr. Martin
>> Kai
Re: Teneo API specification online? [message #615929 is a reply to message #115063] Tue, 18 March 2008 19:50 Go to previous message
Hi Kai,
gr. Martin
> overview.
> Best regards,
> Kai
> Martin Taal wrote:
>> Hi Kai,
>> automatically as
>> gr. Martin
>>> Kai
The Netherlands
Re: Teneo API specification online? [message #615945 is a reply to message #115075] Fri, 21 March 2008 16:37 Go to previous message
Hi Martin,
the newsgroup.
Kai
Martin Taal wrote:
> Hi Kai,
> gr. Martin
>> overview.
>> Best regards,
>> Kai
>> Martin Taal wrote:
>>> Hi Kai,
>>> automatically as
>>> gr. Martin
>>>> Kai
Previous Topic:[Teneo] Association table not created for one-to-many EMF reference
Next Topic:[EMFatic] antlr 3.x IP Quetion
Current Time: Tue Jul 27 16:25:03 GMT 2021
Powered by FUDForum. Page generated in 0.01745 seconds
