Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO] DanglingHREFException after putEPackage()
[CDO] DanglingHREFException after putEPackage() [message #114899] |
Mon, 17 March 2008 09:31 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Hi Eike,
I'm running into the exception mentioned above. I'm not sure if this is
a bug or if I have to modify my generator model(s).
Here's the setting:
I have two packages and a class in each one - I'll use a textual
notation to illustrate the EMF-Models:
package base {
class BaseClass {
attribute counter : EInt;
operation increment() : void;
package derived {
class DerivedClass extends base.BaseClass {
operation decrement() : void;
Package base is defined in base.ecore and base.genmodel. Package derived
is defined likewise in derived.ecore and derived.genmodel, which refers
to base.genmodel. Models validate correctly and model code is generated
as it should.
(This is only an example which I extracted from my code, what I really
want is a package declaring a set of interfaces which classes in other
packages can implement, but the above is the code I used to reproduce
the problem, I can send you the test code if you need it).
Now, what I'm doing is simply creating a container, repository,
transaction, resource etc. and then:
session.getPackageRegistry().putEPackage(BasePackage.eINSTAN CE);
session.getPackageRegistry().putEPackage(DerivedPackage.eINS TANCE);
The first call succeeds, the second one throws an exception:
org.eclipse.net4j.util.io.IORuntimeException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object 'org.eclipse.emf.ecore.impl.EClassImpl@4f15c3 (name: BaseClass) (instanceClassName: null) (abstract: false, interface: false)' is not contained in a resource.
at org.eclipse.emf.cdo.util.EMFUtil.ePackageToString(EMFUtil.ja va:276)
at org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOPackage (ModelUtil.java:162)
at org.eclipse.emf.internal.cdo.util.ModelUtil.getCDOPackage(Mo delUtil.java:128)
at org.eclipse.emf.internal.cdo.CDOPackageRegistryImpl.put(CDOP ackageRegistryImpl.java:85)
at org.eclipse.emf.internal.cdo.CDOPackageRegistryImpl.putEPack age(CDOPackageRegistryImpl.java:64)
at test.CDOPackageRefTests.testPutPackage(CDOPackageRefTests.ja va:97)
at org.junit.internal.runners.TestMethodRunner.executeMethodBod y(TestMethodRunner.java:99)
at org.junit.internal.runners.TestMethodRunner.runUnprotected(T estMethodRunner.java:81)
at org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAfterRunner.java:34)
at org.junit.internal.runners.TestMethodRunner.runMethod(TestMe thodRunner.java:75)
at org.junit.internal.runners.TestMethodRunner.run(TestMethodRu nner.java:45)
at org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestClassMethodsRunner.java:66)
at org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRunner.java:35)
at org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunner.java:42)
at org.junit.internal.runners.TestClassRunner.run(TestClassRunn er.java:52)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:45)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:62)
at org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:118)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:130)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3737)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3374)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2392)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2356)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 22)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:474)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:469)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.sta rt(UITestApplication.java:52)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 564)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1251)
at org.eclipse.equinox.launcher.Main.main(Main.java:1227)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object 'org.eclipse.emf.ecore.impl.EClassImpl@4f15c3 (name: BaseClass) (instanceClassName: null) (abstract: false, interface: false)' is not contained in a resource.
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.endSave(XMLSaveIm pl.java:306)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:270)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1313)
at org.eclipse.emf.cdo.util.EMFUtil.ePackageToString(EMFUtil.ja va:267)
... 52 more
Caused by: org.eclipse.emf.ecore.xmi.DanglingHREFException: The object 'org.eclipse.emf.ecore.impl.EClassImpl@4f15c3 (name: BaseClass) (instanceClassName: null) (abstract: false, interface: false)' is not contained in a resource.
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingH REF(XMLHelperImpl.java:760)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment( XMLHelperImpl.java:731)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHel perImpl.java:753)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefMany(XML SaveImpl.java:1983)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1335)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2665)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1154)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1015)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2366)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1513)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:669)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:586)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256)
... 55 more
So, is this a bug and CDO has Problems handling referenced packages, or
do I have to modify something in my models or code?
(BTW, I updated to HEAD last Thrusday before testing this...)
Stefan
Re: [CDO] DanglingHREFException after putEPackage() [message #114912 is a reply to message #114899] |
Mon, 17 March 2008 12:38 |
Originally posted by: stepper.sympedia.de
Hi Stefan,
This is clearly a bug in CDO. Fortunately it is really minor since it occurs only when you add more than one package in one transaction (commit). If you add them one by one everything should be fine. Background: CDO converts the EPackages into CDOPackages and uses the latter subsequently. In addition the EPackages are converted to XML strings and stored in the backaend, just in case a client does not have the generated Jva code at hand. Then the XML string would be deserialized to the client so that it can use a dynamic model. Also the new Hibernate integration will use this string on the server side to get access to the mapping annotations.
Can you please file a Bugzilla so that we can track the progress of the fix?
Greeting from the EclipseCon ;-)
/Eike
Stefan Winkler schrieb:
> Hi Eike,
> Here's the setting:
> package base {
> class BaseClass {
> package derived {
> as it should.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 52 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> Cheers,
> Stefan
Re: [CDO] DanglingHREFException after putEPackage() [message #114927 is a reply to message #114912] |
Mon, 17 March 2008 16:07 |
--------------000309050507020903050007
Hi Eike,
Comments below ...
Eike Stepper schrieb:
> Hi Stefan,
No, it doesn't :-( - maybe because the PackageManager is part of the
session and not the transaction?
I included my testcase as a Bug attachment.
> the fix?
-> Bug 222974 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=222974>
Oh right, I forgot about the Con ;-) Have fun in California (and do go
shopping, it really pays right now *g*).
Stefan
> /Eike
>> Hi Eike,
>> is a bug or if I have to modify my generator model(s).
>> Here's the setting:
>> package base {
>> class BaseClass {
>> package derived {
>> derived is defined likewise in derived.ecore and derived.genmodel,
>> which refers to base.genmodel. Models validate correctly and model
>> code is generated as it should.
>> really want is a package declaring a set of interfaces which classes
>> in other packages can implement, but the above is the code I used to
>> reproduce the problem, I can send you the test code if you need it).
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> at
>> at
>> ... 52 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 55 more
>> or do I have to modify something in my models or code?
>> Cheers,
>> Stefan
<html>
<head>
http-equiv="Content-Type">
</head>
Hi Eike,<br>
<br>
Comments below ...<br>
<br>
<blockquote cite="mid:frlovc$fs3$1@build.eclipse.org" type="cite">Hi
Stefan,
<br>
<br>
(commit). If you add them one by one everything should be fine. </blockquote>
session and not the transaction?<br>
<br>
I included my testcase as a Bug attachment.<br>
<blockquote cite="mid:frlovc$fs3$1@build.eclipse.org" type="cite">Background:
<br>
<br>
fix?
<br>
</blockquote>
-> <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=222974"
title="NEW - [CDO] DanglingHREFException after putEPackage() when using referencing models">Bug
222974</a>
<blockquote cite="mid:frlovc$fs3$1@build.eclipse.org" type="cite">Greeting
<br>
</blockquote>
shopping, it really pays right now *g*).<br>
<br>
Cheers,<br>
Stefan<br>
<br>
<br>
<blockquote cite="mid:frlovc$fs3$1@build.eclipse.org" type="cite">/Eike
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi Eike,
<br>
<br>
<br>
Here's the setting:
<br>
<br>
<br>
<br>
package base {
<br>
Re: [CDO] DanglingHREFException after putEPackage() [message #114971 is a reply to message #114927] |
Mon, 17 March 2008 18:19 |
Hi Stefan,
I already worked a bit on a fix. But my time is a bit limited due to all the interesting people and talks here at the EclipseCon ;-) I'l keep you informed...
Cheers
/Eike
> Hi Eike,
> Comments below ...
>> Hi Stefan,
>> the fix?
> Cheers,
> Stefan
>> /Eike
>>> Hi Eike,
>>> Here's the setting:
>>> package base {
>>> class BaseClass {
>>> package derived {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
>>> Cheers,
>>> Stefan
Re: [CDO] DanglingHREFException after putEPackage() [message #115009 is a reply to message #114927] |
Mon, 17 March 2008 18:45 |
> Hi Eike,
> Comments below ...
>> Hi Stefan,
I'll work on it later on...
>> the fix?
Oh, yeah! But I've been in New York in January and there's simply no more space available in our wardrobe ;-)
Cheers
/Eike
> Cheers,
> Stefan
>> /Eike
>>> Hi Eike,
>>> Here's the setting:
>>> package base {
>>> class BaseClass {
>>> package derived {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
>>> Cheers,
>>> Stefan
Re: [CDO] DanglingHREFException after putEPackage() [message #116565 is a reply to message #114971] |
Wed, 02 April 2008 08:48 |
--------------050407030807090701090105
Hi Eike,
yesterday I updated to HEAD and tried my testcase and didn't catch an
exception. So I guess you fixed the bug?
Next, I tried to run my project again with the fixed registry, but again
ran into trouble.
What happens is this:
So what I do is as follows:
- I completely wipe the database (using the MySQL administrator, so it
is completely clean )
- I start my application. As part of the initialization process, my
application registers a bunch of packages (say A, B, C and D in that
order) - all goes well.
- I then create two objects - one of a class in package A and one of a
class in package C and commit my model.
- I exit the application.
- I start the application again. As part of the initialization process,
for every package, I try to figure out, if the package is already
registered and if not I register it.
I do this using the following code
|*private **void *registerPackage(EPackage pkg) {
*if *(trace) {
System.out.println("RequipseProjectPlugin.registerPackage("+ pkg.getNsURI() + ")");
CDOPackageRegistry packageRegistry = session.getPackageRegistry();
CDOPackageManager packageManager = session.getPackageManager();
CDOPackage existing = packageManager.lookupPackage(pkg.getNsURI());
*if*(existing == *null*) {
*try *{
packageRegistry.putEPackage(pkg);
*if *(trace) {
System.out.println(" ... done.");
*catch*(Exception e) {
logException(e);
*else if *(trace) {
System.out.println(" ... already exists.");
The result of this is as follows:
- The packages A and C (the ones I created the object with) are
recognized as already registered in the code above.
- The packages B and D are not recognized (|existing == null|).
- Consequently they are tried to be registered, but this leads to a
java.lang.ClassCastException:
org.eclipse.emf.internal.cdo.CDOPackageRegistryImpl$CDOPacka geDescriptor
cannot be cast to org.eclipse.emf.ecore.EPackage
at org.eclipse.emf.cdo.util.EMFUtil.ePackageToString(EMFUtil.ja va:271)
at
org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOPackage (ModelUtil.java:163)
at
at
at
The problem is this:
- When the session is opened, the package registry seems to be populated
with CDOPackageRegistryImpl$CDOPackageDescriptor instances in
org.eclipse.emf.internal.cdo.CDOSessionPackageManagerImpl.
addPackageProxies(...)
- When I try to register an additional package,
org.eclipse.emf.cdo.util.EMFUtil.ePackageToString() iterates through the
registry and casts all elements to EObject, which leads to the exception
given above, because there still are
CDOPackageRegistryImpl$CDOPackageDescriptor instances in the registry.
Bug?
Stefan
> Hi Stefan,
> Cheers
> /Eike
>> Hi Eike,
>> Comments below ...
>>> Hi Stefan,
>>> the fix?
>> go shopping, it really pays right now *g*).
>> Cheers,
>> Stefan
>>> /Eike
>>>> Hi Eike,
>>>> this is a bug or if I have to modify my generator model(s).
>>>> Here's the setting:
>>>> package base {
>>>> class BaseClass {
>>>> package derived {
>>>> classes in other packages can implement, but the above is the code
>>>> I used to reproduce the problem, I can send you the test code if
>>>> you need it).
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 52 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 55 more
>>>> packages, or do I have to modify something in my models or code?
>>>> Cheers,
>>>> Stefan
<html>
<head>
</head>
Hi Eike,<br>
<br>
exception. So I guess you fixed the bug?<br>
<br>
again ran into trouble. <br>
<br>
What happens is this:<br>
<br>
So what I do is as follows:<br>
is completely clean )<br>
order) - all goes well.<br>
model.<br>
- I exit the application.<br>
registered and if not I register it.<br>
<br>
I do this using the following code<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- ======================================================== --><!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = --><!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#7f0055"><b>private
Re: [CDO] DanglingHREFException after putEPackage() [message #116583 is a reply to message #116565] |
Thu, 03 April 2008 07:58 |
Hi Stefan,
Thanks for your detailed description. I won't have time before this
weekend to dig into this issue. In the meantime can you please file a
Bugzilla?
And, as you suspected, the previous issue should have been fixed already.
Due to the EclipseCon I only forgot to update the Bugzilla and tell on the
newsgroup.
Cheers
/Eike
Stefan Winkler wrote:
> Hi Eike,
> ran into trouble.
> *if *(trace) {
> *try *{
> *if *(trace) {
> logException(e);
> *else if *(trace) {
> at
> at
> at
> at
> Bug?
> Cheers,
> Stefan
>> Hi Stefan,
>> Cheers
>> /Eike
>>> Hi Eike,
>>> Comments below ...
>>>> Hi Stefan,
>>>> the fix?
>>> Cheers,
>>> Stefan
>>>> /Eike
>>>>> Hi Eike,
>>>>> Here's the setting:
>>>>> package base {
>>>>> class BaseClass {
>>>>> package derived {
>>>>> you need it).
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 52 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 55 more
>>>>> Cheers,
>>>>> Stefan
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] DanglingHREFException after putEPackage() [message #615902 is a reply to message #114899] |
Hi Stefan,
/Eike
> Hi Eike,
> Here's the setting:
> package base {
> class BaseClass {
> package derived {
> as it should.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 52 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> Cheers,
> Stefan
Cheers
/Eike
Re: [CDO] DanglingHREFException after putEPackage() [message #615906 is a reply to message #114912] |
Hi Eike,
Comments below ...
> Hi Stefan,
> the fix?
Stefan
> /Eike
>> Hi Eike,
>> Here's the setting:
>> package base {
>> class BaseClass {
>> package derived {
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> at
>> at
>> ... 52 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 55 more
>> Cheers,
>> Stefan
<html>
<head>
</head>
Hi Eike,<br>
<br>
<br>
Stefan,
<br>
<br>
<br>
<br>
<br>
fix?
<br>
</blockquote>
222974</a>
<br>
</blockquote>
<br>
Cheers,<br>
Stefan<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Here's the setting:
<br>
<br>
<br>
<br>
package base {
<br>
Re: [CDO] DanglingHREFException after putEPackage() [message #615914 is a reply to message #114927] |
Hi Stefan,
Cheers
/Eike
> Hi Eike,
> Comments below ...
>> Hi Stefan,
>> the fix?
> Cheers,
> Stefan
>> /Eike
>>> Hi Eike,
>>> Here's the setting:
>>> package base {
>>> class BaseClass {
>>> package derived {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
>>> Cheers,
>>> Stefan
Cheers
/Eike
Re: [CDO] DanglingHREFException after putEPackage() [message #615923 is a reply to message #114927] |
> Hi Eike,
> Comments below ...
>> Hi Stefan,
>> the fix?
Cheers
/Eike
> Cheers,
> Stefan
>> /Eike
>>> Hi Eike,
>>> Here's the setting:
>>> package base {
>>> class BaseClass {
>>> package derived {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
>>> Cheers,
>>> Stefan
Cheers
/Eike
Re: [CDO] DanglingHREFException after putEPackage() [message #616056 is a reply to message #114971] |
Hi Eike,
ran into trouble.
*if *(trace) {
*try *{
*if *(trace) {
logException(e);
*else if *(trace) {
at
at
at
at
Bug?
Stefan
> Hi Stefan,
> Cheers
> /Eike
>> Hi Eike,
>> Comments below ...
>>> Hi Stefan,
>>> the fix?
>> Cheers,
>> Stefan
>>> /Eike
>>>> Hi Eike,
>>>> Here's the setting:
>>>> package base {
>>>> class BaseClass {
>>>> package derived {
>>>> you need it).
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 52 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 55 more
>>>> Cheers,
>>>> Stefan
<html>
<head>
</head>
Hi Eike,<br>
<br>
<br>
<br>
<br>
model.<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
Re: [CDO] DanglingHREFException after putEPackage() [message #616058 is a reply to message #116565] |
Hi Stefan,
Bugzilla?
newsgroup.
Cheers
/Eike
> Hi Eike,
> ran into trouble.
> *if *(trace) {
> *try *{
> *if *(trace) {
> logException(e);
> *else if *(trace) {
> at
> at
> at
> at
> Bug?
> Cheers,
> Stefan
>> Hi Stefan,
>> Cheers
>> /Eike
>>> Hi Eike,
>>> Comments below ...
>>>> Hi Stefan,
>>>> the fix?
>>> Cheers,
>>> Stefan
>>>> /Eike
>>>>> Hi Eike,
>>>>> Here's the setting:
>>>>> package base {
>>>>> class BaseClass {
>>>>> package derived {
>>>>> you need it).
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 52 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 55 more
>>>>> Cheers,
>>>>> Stefan
Cheers
/Eike
Current Time: Thu Apr 25 14:33:56 GMT 2024
Powered by FUDForum. Page generated in 0.04921 seconds
