What is the best practice for unit testing plug-in's GUI [message #114876] |
Wed, 10 October 2007 08:54 |
Originally posted by: wjfang.gmail.com
What is the best practice for unit testing plug-in's GUI? I know there is an
automatic GUI recorde in TPTP 4.1. I am wondering why it does not become an
official part of TPTP 4.3. Is there any alternative to fulfill the same goal
in TPTP or Eclipse somewhere?
Thanks a lot,
Jerry
Re: What is the best practice for unit testing plug-in's GUI [message #506664 is a reply to message #114932] |
Fri, 08 January 2010 15:29 |
Dan Corneanu Messages: 10 Registered: July 2009 |
I have an eclipse RCP application (JCommander
http://jcommander.sourceforge.net/). At development time I start the
application from my development eclipse using an "Eclipse Application"
run configuration. Is it possible to use the AGR for recording events
from the tested application (JCommander) and not from the development
eclipse?
Dan Corneanu.
On 10/10/2007 1:44 PM, Paul Slauenwhite wrote:
> Hi Jerry,
> I would recommend using the AGR
> ( http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html)
> to test at the UI level or TPTP JUnit Plug-in tests to test at the API
> level.
> The AGR
> is still a Technology Preview since we do not have the resources to support
> the component in the GA stream (e.g. defects, testing, support, etc).
> Paul
> "Weijian" <wjfang@gmail.com> wrote in message
> news:fei40n$m5f$1@build.eclipse.org...
>> Hi,
>> an
>> an
>> goal
>> Thanks a lot,
>> Jerry
Re: What is the best practice for unit testing plug-in's GUI [message #507168 is a reply to message #506664] |
Tue, 12 January 2010 06:20 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Dan,
Unfortunately, the AGR does not support RCP applications. If your
application were an Eclipse IDE, you could record/playback AGR tests from
both Eclipse instances.
Paul
"Dan Corneanu" <corneanu_dan@yahoo.com> wrote in message
news:hi7ivu$rkl$1@build.eclipse.org...
> eclipse?
> Best regards,
> Dan Corneanu.
>> Hi Jerry,
>> level.
>> The AGR
>> support
>> Paul
>>> Hi,
>>> is
>>> an
>>> an
>>> goal
>>> Thanks a lot,
>>> Jerry
FUDForum. Page generated in 0.03467 seconds
