Re: [Texo] How to create ecore file with sub-packages? [message #875119 is a reply to message #875086] |
Tue, 22 May 2012 07:19 |
Olaf Burdziakowski Messages: 46 Registered: April 2012 |
Member |
@Martin,
could you please attach/send the example you have? I would like to analyse how it is defined.
I spend yesterday whole day on combinig/guessing how to connect my ecore files into single one.
Finally I managed it works. I copied manually ecore files into single file. I had to define manually sub-packages and update references.
I think Texo should be able to do that too. For me it does not matter if it would be from xsd files or from ecore files but it would be very helpful feature.
Now I have single ecore file with 7 sub packages and generate correct code from the file. The file can be opened in editor even after code generation (all necessary classes are in single location, not in separate package folders). Now I can create master class that would be annotated, easy to manage group of xml files with save to database. This is what I needed.
Can you please think how to automate combining several schemas (xsd or ecore) into single ecore file?
[Updated on: Tue, 22 May 2012 07:21] Report message to a moderator
Re: [Texo] How to create ecore file with sub-packages? [message #875223 is a reply to message #875119] |
Tue, 22 May 2012 10:45 |
Hi Olaf,
But this sounds like a lot of work for you, each time you now change the xsd you have to manually update this
master/combined ecore file. The problem is that when changing an xsd I would need to know in which ecore file the model
is stored. Currently this is done by name, so a abc.xsd will update the abc.ecore and use a abc.annotationsmodel file.
But with multiple xsd files to one ecore file that's not really possible. At least not without having some xsd-ecore
linking information somewhere.
To be honest without a clear solution direction this feature does not have my highest priority.
gr. Martin
On 05/22/2012 09:19 AM, Olaf Burdziakowski wrote:
> @Martin,
> update references.
> Now I have single ecore file with 7 sub packages. Generate correct code from the file. The file can be opened in editor
> needed.
> Can you please think how to automate combining several schemas (sxd or ecore) into single ecore file?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03216 seconds
