Re: "Operation Failed" during remote ftp access [message #878012 is a reply to message #877988] |
Mon, 28 May 2012 10:01 |
Alberto Gomez Messages: 8 Registered: May 2012 |
Well I guess It will be better if I ellaborate a little bit.
This is really odd specially because the RSE FTP used to work flawlessly, when all out of a sudden stopped working , and I don't think I did anything to break it.
Basically when I connect trough ftp, everything is fine, it gets connected, because I can see in the console the server responding toand the last ftp command sent to the server is a PASV, and the server doesnt seem to respond.(Although it does with an "227 entering passive mode" but I can only see this monitoring the connection with wireshark, not in the console).
I've tried changing the mode to not passive, and I get same result , but obviously without PASV command.
I don't think the priblem involves a firewall or a server setting, I have connected with some other software with same ftp settings included passive mode, and I haven't had any trouble.
As I said I tried monitoring the connection with wireshark and I noticed that right after the last successful message, the RSE sends a message that wireshark marks as having an "incorrect ip checksum (maybe caused by 'ip checksum offload')".I'm not a tcp/ip expert, I just thought It could give some extra information to any kind soul that is able to help us
Re: "Operation Failed" during remote ftp access [message #878520 is a reply to message #878400] |
Tue, 29 May 2012 13:24 |
On 5/29/2012 2:36 AM, Alberto Gomez wrote:
> I'm a bit hopeless, looking at the number of views of this post I can
> see more that 1000 have read it, but no one replied.
> Anyway, I've found another bit of information .
> The first time the rse tries to connect the error message is
> different(only the first time)
> this is :Operation failed due to network I/O error
> 'java.net.SocketException: Connection reset by peer: socket write error'
> Please, If we are posting in the wrong place or not following the rules,
> somebody, say something!
(No, your post is fine. You do realize that last weekend was a major US
holiday? Fewer respondants may have been present in the forum.)
Re: "Operation Failed" / "Connection reset by peer: socket write error" [message #899024 is a reply to message #874556] |
Mon, 30 July 2012 08:38 |
Stefan M Messages: 5 Registered: July 2012 |
Hello Guys
Using the older vm really do it for me too (thank you very much for this hint). But there must be another secret. I am using different FTP connections to different FTP servers and some of them working others not. So this behavior must also depend on the servers (settings? software? how to figure out which server/settings is installed on a host?)
Ok, iam not the "Serverman" but maybe this could be another brick to build a solution.
adios, Stefan
[Updated on: Mon, 30 July 2012 09:10] Report message to a moderator
FUDForum. Page generated in 0.10487 seconds
