help! CoreException [message #114779] |
Wed, 10 October 2007 01:38 |
Originally posted by: No_SPAM_PLS_achan.progress.com
I'm getting the following exception when I profile my app. When I create
a brand new eclipse project and create a simple helloworld example, then
the profiling works. However, I'm getting this exception with my app
every time.
Thanks in advance for your help.
-Aston
org.eclipse.core.runtime.CoreException
A time-out occurred while attempting to launch the process
org.eclipse.core.runtime.CoreException: A time-out occurred while
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:123)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:131)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.handleError(TIDelegateHelper.java:597)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launchProcess(TIDelegateHelper.java:513)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.launch(TIDelegateHelper.java:313)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIJ avaLauncherDelegate.launch(TIJavaLauncherDelegate.java:37)
at
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1153)
at
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:196)
Re: help! CoreException [message #115020 is a reply to message #114843] |
Wed, 10 October 2007 13:16 |
Originally posted by: _NO_SPAM_PLZ_achan.progress.com
Igor,
I am using eclipse 3.3. Here are the tptp info:
TPTP Monitoring Tools Project: 4.4.1.v200706132116
TPTP Platform Project: 4.4.1.v200706132116
TPTP Profiling for Web Apps: 4.4.1.v200709261752
TPTP Reporting with BIRT: 4.4.1v200706132116
TPTP Testing Tools Project: 4.3.101.v200709261752
TPTP Tracing and Profiling Tools Project: 4.3.1.v200709261752
I actually re-installed eclipase 3.3 last night and used update manager to
install tptp.
The agent controller is running as an NT service. Platform is WindowsXP. I
couldn't get IAC to work at all.
Agent Controller version is 4.4.0.0
Thanks.
-Aston
"Igor Alelekov" <igor.alelekov@intel.com> wrote in message
news:58d47094863799972a91124b7da8c50f$1@www.eclipse.org...
> Hi Aston,
> What TPTP build are you using?
> Are you using filters while profiling your application? Filters can
> decrease volume of profiling data.
> What percentage number are you seeing on status bar in the "Launching new
> configuration" message?
> Regards,
> Igor
Re: help! CoreException [message #115059 is a reply to message #115020] |
Wed, 10 October 2007 14:12 |
I tried to upgrade to latest from the Tech Preview site. Selected TPTP Tech
Preview but it complained about
Tooling for Web Services Distributed Management (WEDM) (4.3.0.v2006 ...)
requries plug-in org.wsdl4j
Clicking on "Select Required" didn't fix the problem.
Any idea?
Thanks.
-Aston
"A Chan" <_NO_SPAM_PLZ_achan@progress.com> wrote in message
news:feijc2$380$1@build.eclipse.org...
> Igor,
> install tptp.
> I couldn't get IAC to work at all.
> Thanks.
> -Aston
>> Hi Aston,
>> Regards,
>> Igor
Re: help! CoreException [message #115085 is a reply to message #115059] |
Wed, 10 October 2007 15:02 |
Finally downloaded
tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.1-20071003010 0.zip again and
tried it.
Same result.
-Aston
news:feimk9$c2d$1@build.eclipse.org...
>Tech Preview but it complained about
> Any idea?
> Thanks.
> -Aston
>> Igor,
>> to install tptp.
>> Thanks.
>> -Aston
>>> Hi Aston,
>>> new configuration" message?
>>> Regards,
>>> Igor
Re: help! CoreException [message #115110 is a reply to message #115059] |
Wed, 10 October 2007 15:13 |
Mauro Molinari pointed me to this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201474
I tried the SocketTL.dll and it worked!
Thanks.
-Aston
> Any idea?
> Thanks.
> -Aston
>> Igor,
>> to install tptp.
>> Thanks.
>> -Aston
>>> Hi Aston,
>>> Regards,
>>> Igor
Re: help! CoreException [message #115223 is a reply to message #115110] |
Thu, 11 October 2007 07:34 |
> Thanks.
> -Aston
Hi Aston,
for your (and the community) convenience, I write here too.
You have to upgrade your stand-alone agent controller to version
agntctrl.win_ia32-TPTP-4.4.1-200710030100.zip in order to make profiling
work.
However, in the mentioned bug report I outlined the fact that the IAC
still doesn't work (for me, at least...).
Mauro.
FUDForum. Page generated in 0.02274 seconds
