Home » Eclipse Projects » Remote Application Platform (RAP) » Single-sourcing with E4 apps?
Single-sourcing with E4 apps? [message #874062] Sat, 19 May 2012 17:58 Go to next message
Does RAP support E4 applications based on the programming model where you use E4's provided E4Application class instead of setting up your own Display and workbench? It seems hard to move the initializations done in the E4Application class into an EntryPoint in the way people seem to do that with 3.x-apps...
Besides, from reading bugzilla I gather that there might already be an entry point, or at least ApplicationConfiguration, registered for the E4 app? I am led to believe that's the case because I get the following exception when I try to register my own ApplicationConfiguration with EntryPoint "org.osgi.service.http.NamespaceException: The alias '/rwt-resources' is already in use."
If the E4 app already registers an entry point, how can I launch the RAP app based on that entry point? If I just do Run without specifying anything, I get an error saying that entry point /default does not exist...
[Updated on: Sat, 19 May 2012 17:59] by Moderator
Re: Single-sourcing with E4 apps? [message #874563 is a reply to message #874062] Mon, 21 May 2012 02:53 Go to previous messageGo to next message
Search this forum - RAP does not yet support e4 and if you'd get it up
and running you'll notice that there are blocking problems in a
multi-user env (in this case the IEventBroker!)
Tom
Am 19.05.12 23:58, schrieb William Saar:
> Display and GUI? It seems hard to move the initializations done in the
> with 3.x-apps...
Re: Single-sourcing with E4 apps? [message #874582 is a reply to message #874563] Mon, 21 May 2012 03:31 Go to previous messageGo to next message
Thanks! Sounds like the question is a good candidate to answer in the FAQ as well Smile
Re: Single-sourcing with E4 apps? [message #874961 is a reply to message #874582] Mon, 21 May 2012 17:25 Go to previous message
We have plans to look into RAP on Eclipse 4, maybe for RAP 2.0, but no
promises yet.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Previous Topic:URL with token
Next Topic:Detect "mouseleave" event
Current Time: Tue Jul 08 21:05:35 EDT 2025
Powered by FUDForum. Page generated in 0.10381 seconds
