Home » Archived » Visual Editor (VE) » Create Visual SWT class not directly from Composite but from derived class
Create Visual SWT class not directly from Composite but from derived class [message #114531] Thu, 05 January 2006 06:41 Go to next message
I want to create a SWT visual class not directly from Comoposite but from
a dreived class. Example:
public class Screen extends Composite
public class PreferenceScreen extends Screen
If I try to create now PreferenceScreen as a visual SWT class, I cannot
work with the VE because the typical Composite surface does not appear.
How can I solve this problem ? I am using VE 1.1 on Eclipse 3.1, does a
upgrade to 1.2 help?
Many thanks in advance and a happy new year!
René
Re: Create Visual SWT class not directly from Composite but from derived class [message #115222 is a reply to message #114531] Tue, 10 January 2006 11:54 Go to previous messageGo to next message
Hi Rene,
> public class Screen extends Composite public class PreferenceScreen
> extends Screen
It should. This is no different from Canvas extends Composite and the
custom widgets that extend Canvas. Is there anything in the Error Log ?
What happens when you open the VE - what do you see instead of the visual
surface ?
Joe Winchester
Re: Create Visual SWT class not directly from Composite but from derived class [message #119810 is a reply to message #115222] Sat, 04 March 2006 10:15 Go to previous messageGo to next message
Hello Joe,
first thanks for your answer and sorry for my late reply. I just don't see
anything on the visual surface, the whole composite disappears.
The Exception that occurs:
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
org.eclipse.jem.internal.proxy.initParser.tree.NoExpressionV alueException:
Proxy id: 0
at
org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.pushExpressionProxy(ExpressionProcesser.java:829)
at
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:320)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
at
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
at
org.eclipse.jem.internal.proxy.vm.remote.CallbackHandler.cal lbackWithParms(CallbackHandler.java:150)
at
org.eclipse.ve.internal.swt.targetvm.DisplayExec$1.run(Displ ayExec.java:111)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:541)
at
org.eclipse.ve.internal.swt.targetvm.DisplayExec$ExecRunnabl e.run(DisplayExec.java:109)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3264)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2910)
at
org.eclipse.ve.internal.swt.targetvm.Environment$3.run(Envir onment.java:121)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
Proxy id: 0
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
at
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
at
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
at
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:983)
at
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.notifyCha nged(BeanProxyAdapter.java:2003)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:230)
at
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:113)
at
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:101)
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleEObject.dynamicSet(EStructuralFeatureImpl .java:2384)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:649)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:623)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:605)
at
org.eclipse.jem.internal.instantiation.base.JavaInstance.set Allocation(JavaInstance.java:104)
at
org.eclipse.ve.internal.java.codegen.java.ConstructorDecoder Helper.decode(ConstructorDecoderHelper.java:610)
at
org.eclipse.ve.internal.swt.codegen.SWTConstructorDecoderHel per.decode(SWTConstructorDecoderHelper.java:283)
at
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.decode(AbstractExpressionDecoder.java:154)
at
org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .refreshFromJOM(CodeExpressionRef.java:540)
at
org.eclipse.ve.internal.java.codegen.java.BDMMerger.processE quivalentExpressions(BDMMerger.java:585)
at
org.eclipse.ve.internal.java.codegen.java.BDMMerger.processI nitExpressions(BDMMerger.java:1108)
at
org.eclipse.ve.internal.java.codegen.java.BDMMerger.updateRe gularBeanPartExpressions(BDMMerger.java:1066)
at
org.eclipse.ve.internal.java.codegen.java.BDMMerger.mergeAll Beans(BDMMerger.java:929)
at
org.eclipse.ve.internal.java.codegen.java.BDMMerger.merge(BD MMerger.java:105)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.merge(JavaSourceTranslator.java:388)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.handleParseable(JavaSourceTranslator .java:434)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$SharedToLocalUpdater.run(JavaSourceTranslator.java:502)
at
org.eclipse.ve.internal.java.codegen.java.SnippetParseJob.do Run(SnippetParseJob.java:92)
at
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Addendum [message #119821 is a reply to message #119810] Sat, 04 March 2006 10:19 Go to previous messageGo to next message
Forgot to mention that now I use VE 1.2 M2. The problem occured also in
the VE 1.1 Version.
Greets,
René
Re: Addendum [message #119861 is a reply to message #119821] Sun, 05 March 2006 17:36 Go to previous messageGo to next message
Please attach the entire .log file. the error displayed is typically one
that results because there was another error before that.
Make sure that you are using Eclipse SDK 3.2M5a, GEF 3.2M5, EMF 2.2M5
with VE 1.2M2.
> the VE 1.1 Version.
> Greets,
> René
Rich Kulp
Re: Addendum [message #120221 is a reply to message #119861] Tue, 07 March 2006 13:37 Go to previous messageGo to next message
Thanks for your help. Im am using Eclipse SDK 3.2M5a, GEF 3.2M5, EMF 2.2M5
with VE 1.2M2. The logfile is quite large thats why I put it online:
http://www.ososoft.de/logfile/logfile.log
If I Change
public class WelcomeScreenPL extends Composite
to
public class WelcomeScreenPL extends ScreenPL
(ScreenPL is derived from Composite)
Then the visual area disappears and the errors occur. What can I do, does
a workaround for this Problem exist? Would be great if I can use the VE
with derived classes cause we are working here on a large framework and
this would save quite a lot time.
Greets,
René
Re: Addendum [message #120234 is a reply to message #120221] Tue, 07 March 2006 14:29 Go to previous message
Ah, I wasn't clear to me at first what you were trying to do.
Unfortunately the VE doesn't support subclass of a subclass of a visual
class. We only really support direct subclasses of a visual. :-(
> 2.2M5 with VE 1.2M2. The logfile is quite large thats why I put it online:
> If I Change
> to
> does a workaround for this Problem exist? Would be great if I can use
> the VE with derived classes cause we are working here on a large
> framework and this would save quite a lot time.
> Greets,
> René
Rich Kulp
Re: Create Visual SWT class not directly from Composite but from derived class [message #611778 is a reply to message #114531] Tue, 10 January 2006 11:54 Go to previous message
Hi Rene,
> extends Screen
surface ?
Joe Winchester
Re: Create Visual SWT class not directly from Composite but from derived class [message #612251 is a reply to message #115222] Sat, 04 March 2006 10:15 Go to previous message
Hello Joe,
Proxy id: 0
at
at
at
at
at
at
at
at
at
at
Proxy id: 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Addendum [message #612252 is a reply to message #119810] Sat, 04 March 2006 10:19 Go to previous message
the VE 1.1 Version.
Greets,
René
Re: Addendum [message #612255 is a reply to message #119821] Sun, 05 March 2006 17:36 Go to previous message
with VE 1.2M2.
> the VE 1.1 Version.
> Greets,
> René
Rich Kulp
Re: Addendum [message #612284 is a reply to message #119861] Tue, 07 March 2006 13:37 Go to previous message
If I Change
to
Greets,
René
Re: Addendum [message #612285 is a reply to message #120221] Tue, 07 March 2006 14:29 Go to previous message
> If I Change
> to
> Greets,
> René
Rich Kulp
Previous Topic:swingX for VE
Next Topic:Extract the editpart for a specific component
Current Time: Wed Jul 09 12:57:50 EDT 2025
Powered by FUDForum. Page generated in 0.06493 seconds
