Home » Eclipse Projects » BIRT » Problem with BIRT Report Viewer - missing JS files
Problem with BIRT Report Viewer - missing JS files [message #873165] Thu, 17 May 2012 16:09 Go to next message
Ravi Gogna is currently offline Ravi GognaFriend
Hi all,
First time poster, and a real BIRT newbie so apologies in advance for any missing details. I am trying to write a report in Eclipse and view it via an iframe in my webapp.
I created the report in Eclipse (3.7, using BIRT 2.6.0) and then:
- downloaded and installed the report viewer into the webapps folder
- copied my report into the birt-report webapp folder
I then tried running the report and the iframe did appear, but it ran with the following errors:
Line 468
Char: 2
Error: 'Constants' is undefined
Code: 0
URL: XXX
Line 486
Char: 5
Code: 0
URL: XXX
Line 530
Char: 3
Error: Object expected
Code: 0
URL: XXX
Line 542
Char: 4
Error: 'birtUtility' is undefined
Code: 0
URL: XXX
By looking at the source of the iframe, I saw that Constants and birtUtility both seem to be .js files that should be at birt/ajax/utility/ but when I look there there are no files (and actually there are no .js files anywhere in /birt/). By going to the relevant lines in the source, I am guessing that there are missing classes. Do I have to run some additionally installation to get the JARs to build? And where do those Javascript files come from?
Any help very gratefully received!
Re: Problem with BIRT Report Viewer - missing JS files [message #873672 is a reply to message #873165] Fri, 18 May 2012 20:08 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Why not try the tag library with the viewer installed?
http://www.eclipse.org/birt/phoenix/deploy/viewerUsageMain.php#tags
Jason
On 5/17/2012 12:09 PM, Ravi Gogna wrote:
> Hi all,
> Line 468 Char: 2 Error: 'Constants' is undefined Code: 0 URL: XXX
> Line 486 Char: 5 Error: 'Constants' is undefined Code: 0 URL: XXX
> Line 530 Char: 3 Error: Object expected Code: 0 URL: XXX
> Line 542 Char: 4 Error: 'birtUtility' is undefined Code: 0 URL: XXX
Previous Topic:Deploying BIRT Report to Tomcat with MongoDB ODA
Next Topic:Date Picker for Eclipse 3.7
Current Time: Mon Feb 24 21:13:05 GMT 2020
Powered by FUDForum. Page generated in 0.01941 seconds
