Home » Eclipse Projects » BIRT » Steps to create reportdesign using java api.(Request to help with steps to create dynamic charts/reports in birt using java classes.)
Steps to create reportdesign using java api. [message #872755] Wed, 16 May 2012 18:50 Go to next message
Debarshi Dasgupta is currently offline Debarshi DasguptaFriend
Hi All,
I feel BIRT is very powerful but still not explored properly. I want to create reports/chart using java apis so that the reports/charts can be generated and customized dynamically as per users requirement.
I want to design an application where users will be allowed to create charts on parameters selected by them. And in the back-end depending on the selected parameters reports will be generated.
Re: Steps to create reportdesign using java api. [message #873184 is a reply to message #872755] Thu, 17 May 2012 16:35 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
The dev share on birt-exchange.org has a lot of examples. One thing you
might want to look at is calling script that changes the report based on
parameters. Look at this example:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/992-change-chart-series-type-with-script/
Jason
On 5/16/2012 2:50 PM, Debarshi Dasgupta wrote:
> Hi All,
Previous Topic:Export to pdf option not available
Next Topic:Unable to change the run time connection properties of data source using JTDS driver
Current Time: Wed Feb 26 23:42:41 GMT 2020
Powered by FUDForum. Page generated in 0.03270 seconds
