Home » Archived » BIRT » Different EMF DataSoruce
Different EMF DataSoruce [message #872484] Wed, 16 May 2012 07:54 Go to next message
Dennis Melzer is currently offline Dennis MelzerFriend
i want to print a SWT Table with a EMF Model. The EMF Model is stored in a xmi file. At runtime the user can choose the storage location for the xmi file.
1. Is a data source the stored xmi file or the ecore file?
If data source the xmi file(s):
2. How can i add this (different) data source in birt?
Is there a Tutorial for EMF and Birt?
[Updated on: Wed, 16 May 2012 08:06]
Report message to a moderator
Re: Different EMF DataSoruce [message #872511 is a reply to message #872484] Wed, 16 May 2012 08:51 Go to previous messageGo to next message
You'll need to use EMFs ODA adapter.
On 16/05/2012 9:54 AM, Sir Wayne wrote:
> Hello,
> the xmi file.
> Thanks
Ed Merks
Re: Different EMF DataSoruce [message #872520 is a reply to message #872511] Wed, 16 May 2012 09:07 Go to previous messageGo to next message
Ed Merks wrote on Wed, 16 May 2012 04:51
Yes i know. I can choose a EMF Ecore Data Source --> Resource.
Re: Different EMF DataSoruce [message #872648 is a reply to message #872520] Wed, 16 May 2012 14:20 Go to previous messageGo to next message
I tried out: http://timezra.blogspot.de/2008/04/oda-ecore-getting-started-guide.html, but i doesn't understand two things:
1. Do I need a ecore File or a instance of a ecore File?
2. If I need a instance of a ecore file, how can i switch the file at the runtime for a rcp application?
Defaultname.ecore has 1 class Peron {name}
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="defaultname"
    nsURI="http://defaultname/1.0" nsPrefix="defaultname">
  <eClassifiers xsi:type="ecore:EClass" name="Person">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
      <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
        <details key="wildcards" value=""/>
        <details key="name" value="hh:mm"/>
      </eAnnotations>
    </eStructuralFeatures>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="date" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDate">
      <eAnnotations source="FormattedControl" references="#//Person/date/%FormattedControl%">
        <details key="format" value="dd.mm.yyyy"/>
      </eAnnotations>
  </eClassifiers>
</ecore:EPackage>
Instance Person.xmi
<?xml version="1.0" encoding="ASCII"?>
<defaultname:Person xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:defaultname="http://defaultname/1.0" xsi:schemaLocation="http://defaultname/1.0 DefaultName.ecore" name="test"/>
3. Did the Query-Wizard change?
[Updated on: Wed, 16 May 2012 14:28]
Re: Different EMF DataSoruce [message #872709 is a reply to message #872648] Wed, 16 May 2012 16:42 Go to previous messageGo to next message
Comments below.
On 16/05/2012 4:20 PM, Sir Wayne wrote:
> I tried out:
An instance file, which is parsed using the generated model. Assuming
you're using a generated model...
> <eAnnotations
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> Instance Person.xmi
> name="test"/>
This seems to suggest your instance file is in the same folder as the
Ecore model file. Be sure to open the instance file with an absolute
URI, e.g, file:/c:/folder/Person.xmi so that the relative reference to
the Ecore model file can be resolved properly.
Ed Merks
Re: Different EMF DataSoruce [message #872757 is a reply to message #872709] Wed, 16 May 2012 18:55 Go to previous message
Ed Merks wrote on Wed, 16 May 2012 12:42
Comments below.
Which one exactly do you mean?
Iam confused, if i use a ecore file as datasource, then i can only select ecore types (EAttribute, EAnnotation, EClass ...)in a dataset.
If i use a stored xmi file, i cant't select anything, the list is empty.
Previous Topic:Formatting numbers
Next Topic:Tabs and Dashboard
Current Time: Tue Apr 16 07:56:48 GMT 2024
Powered by FUDForum. Page generated in 0.01916 seconds
