Home » Eclipse Projects » Remote Application Platform (RAP) » How to disable the whole application.
How to disable the whole application. [message #872325] Tue, 15 May 2012 22:45 Go to next message
Jesus   Luna Quiroga is currently offline Jesus Luna QuirogaFriend
Member
I have an application that uses JMS with RAP and since the JMS messages are asynchronous the application uses a simple mechanism to block or disable the whole application while a JMS message is sent and received.
The process or mechanism is the following:
- When a request is done a JMS message is sent and the application is disabled:
display.getActiveShell().setEnabled(false);
- A JMS message is received by a background thread, using the UICallback the application is enabled:
display.syncExec(new Runnable() {
public void run() {
All this works fine, but every time the application is disabled it turns all grayed out and since this mechanism is heavily used it doesn't look ok.
I want to know if there is another way to disable the whole application in order to avoid the grayed look and have a smoother way to do this.
I hope you can help me with this!
Re: How to disable the whole application. [message #873458 is a reply to message #872325] Fri, 18 May 2012 09:17 Go to previous message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi.
The only other way i can think of is to place a transparent shell over
the entire viewport. That way the user cant click anything.
Greetings,
Tim
Am 16.05.2012 00:45, schrieb Jesus Roberto Luna Quiroga:
> disabled:
> public void run() {
Tim Buschtöns
Twitter: @EclipseRAP
Previous Topic:Jboss problems with javax.servlet
Next Topic:How to protect your rap product?
Current Time: Sun Dec 05 15:32:28 GMT 2021
Powered by FUDForum. Page generated in 0.01286 seconds
