Jaas Login integration refresh problem [message #871480] |
Mon, 14 May 2012 02:23  |
I have following problem with Jaas Login integration. After I have integrated my application with Equinox Security Framework using Wiki example (wiki.eclipse.org/RAP/Equinox_Security_Integration). My application starts and login-box is shown to user. When I try to login (with/ without Name/Pass) and then try to refresh (F5) my application, all works fine, but when I try to refresh (F5) my application direct after it has been started, it crashes/doesn't response anymore - I have to restart my server (the same problem appears in the Wiki example). It seems for me to be a problem with Lifecycle: components are not right disposed or there is a some problem with UIThread.
What I have to add/change in my code to avoid crashes after the login box is being refreshed?
Maybe this problem is alraedy known, but I haven't found any helpfully informations about it.
Thank you for any hints.
Re: Jaas Login integration refresh problem [message #872955 is a reply to message #871480] |
Thu, 17 May 2012 03:11  |
Hi all,
I've managed to reproduce the issue with the demo project attached to
the Wiki page for RAP and Equinox Security integration. I've opened a
bug to track the progress on it:
379785: Unable to restart the session (F5) under some constellation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=379785
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03330 seconds
