Re: Egit unable to clone shared repo [message #871655 is a reply to message #871633] |
Mon, 14 May 2012 16:23 |
Fazle Khan Messages: 6 Registered: May 2012 |
Junior Member |
Here what I'm seeing in the eclipse log
!SESSION 2012-05-11 17:20:19.199 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_16
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 2 0 2012-05-11 17:20:24.351
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-05-11 17:20:24.351
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
!ENTRY com.adobe.flexbuilder.ui 4 1 2012-05-11 17:20:27.797
!MESSAGE Product = null version = 460 edition = stnd
!SESSION 2012-05-14 10:55:56.861 -----------------------------------------------
!ENTRY org.eclipse.ui 2 0 2012-05-14 10:56:04.269
!SUBENTRY 1 org.eclipse.ui 2 0 2012-05-14 10:56:04.269
!ENTRY com.adobe.flexbuilder.ui 4 1 2012-05-14 10:56:10.257
!ENTRY org.eclipse.egit.ui 4 0 2012-05-14 11:02:29.198
!MESSAGE Invalid thread access
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:359)
at org.eclipse.swt.widgets.Text.getText(Text.java:1117)
at org.eclipse.egit.ui.UIUtils$2.updateProposals(UIUtils.java:291)
at org.eclipse.egit.ui.internal.components.RepositorySelectionPage.getGitRepositoryInfo(RepositorySelectionPage.java:1018)
at org.eclipse.egit.ui.internal.clone.AbstractGitCloneWizard.executeCloneOperation(AbstractGitCloneWizard.java:433)
at org.eclipse.egit.ui.internal.clone.AbstractGitCloneWizard.access$2(AbstractGitCloneWizard.java:424)
at org.eclipse.egit.ui.internal.clone.AbstractGitCloneWizard$5.run(AbstractGitCloneWizard.java:386)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
!ENTRY org.eclipse.egit.ui 4 0 2012-05-14 11:26:50.679
!STACK 0
When I try initializing the repo with standard http (i.e no ssl) then modifying the repository to use ssl and push a change up via egit this I see this in the log
!ENTRY org.eclipse.egit.core 4 0 2012-05-14 11:29:20.646
!MESSAGE An exception occurred during push on URI h t t p s://fkhan.no-ip.org/git/repo.git: An internal Exception occurred during push: h t t p s://fkhan.no-ip.org/git/repo.git: cannot open git-receive-pack
!STACK 0
org.eclipse.jgit.api.errors.JGitInternalException: Exception caught during execution of push command
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:156)
at org.eclipse.egit.core.op.PushOperation.run(PushOperation.java:227)
at org.eclipse.egit.ui.internal.push.PushOperationUI.execute(PushOperationUI.java:145)
at org.eclipse.egit.ui.internal.push.PushOperationUI$1.run(PushOperationUI.java:202)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.jgit.errors.TransportException: h t t p s://fkhan.no-ip.org/git/repo.git: cannot open git-receive-pack
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:466)
at org.eclipse.jgit.transport.TransportHttp.openPush(TransportHttp.java:365)
at org.eclipse.jgit.transport.PushProcess.execute(PushProcess.java:130)
at org.eclipse.jgit.transport.Transport.push(Transport.java:1120)
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:152)
... 4 more
Caused by: java.io.IOException: HTTPS hostname wrong: should be <fkhan.no-ip.org>
at sun.net.www.protocol.https.HttpsClient.checkURLSpoofing(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(Unknown Source)
at org.eclipse.jgit.util.HttpSupport.response(HttpSupport.java:167)
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:429)
... 8 more
!ENTRY org.eclipse.egit.core 4 0 2012-05-14 11:31:39.016
!STACK 0
... 4 more
... 8 more
The push however works if I run git push from the command line. I verifying the remote repo configuration via the "git remote -v" command and the urls are using ssl
FUDForum. Page generated in 0.25078 seconds
