Home » Modeling » TMF (Xtext) » Xtext generator grammar from Ecore model(Problem with Xtext generation)
Xtext generator grammar from Ecore model [message #871201] Fri, 11 May 2012 12:09 Go to next message
frank fotso is currently offline frank fotsoFriend
Member
Morning everybody,
hope everything is cool on your side , for me is not the case . In fact ,
i have a problem with Xtext. when i generate my Dsl from an ecore model i have 2 warnings which leads me to execution errors .
the 2 warnings are:
- The imported package is not on the classpath of this project which may lead to follow up errors.
- The imported package refers to elements the package registry instead of using the instances from the workspace.
i have tried all hte possible solution i saw on the net but still have the same warning , hope someboby can help me.
My regards , frank
Re: Xtext generator grammar from Ecore model [message #871279 is a reply to message #871201] Fri, 11 May 2012 17:59 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
which Xtext Version do you use? can you share a reproducable example.
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Xtext generator grammar from Ecore model [message #872145 is a reply to message #871279] Tue, 15 May 2012 14:34 Go to previous message
Member
i'm using version eclipse-SDK-3.7.1-Xtext-2.2.1-win32
i've put somme picture showing the differents errors and also the package of the project.
  • Attachment: All.zip
    (Size: 314.33KB, Downloaded 80 times)
  • Attachment: Test1.png
    (Size: 138.16KB, Downloaded 91 times)
  • Attachment: Test2.png
    (Size: 71.39KB, Downloaded 87 times)
  • Attachment: Test3.png
    (Size: 75.34KB, Downloaded 84 times)
Previous Topic:need to accept backslashes in the language
Next Topic:EMap support
Current Time: Sun Jan 17 11:01:54 GMT 2021
Powered by FUDForum. Page generated in 0.01623 seconds
