Home » Modeling » BPEL Designer » Working directory does not exist
Working directory does not exist [message #871108] Thu, 10 May 2012 17:22 Go to next message
I installed BPEL eclipse plugin on two computers and both have the same problem.
ODE v1.x server comes with the package, but can not be re-configured to run. In the launch configuration dialog, it has /your_tomcat_root/ for working directory. I can change it to some directory in my file system, hit apply, the red error message goes away, but when I reopen the dialog, it is back to /your_tomcat_root/.
Is this a permission problem? any one seen this before?
Re: Working directory does not exist [message #871498 is a reply to message #871108] Mon, 14 May 2012 04:51 Go to previous messageGo to next message
I am facing the same problem and is stuck with it since last week.
Re: Working directory does not exist [message #872443 is a reply to message #871108] Wed, 16 May 2012 02:04 Go to previous messageGo to next message
Hi Bruce,
I could solve this problem by using 'Check for updates' and installing the updates. After I did this, I started to add an Ode Server and this time I got the necessary screen to input Tomcat home directory and Ode Home Directory.
Hope this would help u too,
Sreeparna Pal
Re: Working directory does not exist [message #873107 is a reply to message #872443] Thu, 17 May 2012 10:02 Go to previous message
This should be fixed now. Please try again.
Bob
Previous Topic:Problem when open a bpel file
Next Topic:Asynchronous Bpel
Current Time: Mon Jul 14 12:59:42 EDT 2025
Powered by FUDForum. Page generated in 0.28716 seconds
