Home » Modeling » TMF (Xtext) » error running workflow
error running workflow [message #870523] Tue, 08 May 2012 14:20 Go to next message
Vlad Dumitrescu is currently offline Vlad DumitrescuFriend
Hi!
I have a very strange problem: I tried to run my mwe2 again (after a while) and I get
0 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Couldn't find module org.erlide.Erlang
java.lang.IllegalStateException: Couldn't find module org.erlide.Erlang
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:77)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:71)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
I tried with a fresh workspace and it worked fine. After restarting Eclipse (with the new workspace), the same error as above happens...
I created in the same workspace (without restarting) the arithmetics example, where the mwe2 ran fine. Getting back to my project, surprise!: now I can run it! Switching to another workspace and back, it gives an error again...
Importing the arithmetics example in another workspace didn't help even for a short while.
Does anyone know what may be going on?
regards,
Vlad
Re: error running workflow [message #870525 is a reply to message #870523] Tue, 08 May 2012 14:25 Go to previous messageGo to next message
Holger Schill is currently offline Holger SchillFriend
Member
Looks like a building problem in the ws. The modules of the workflows
must be in the index so that the launcher could find them. A clean
should help. ;-)
Holger
Re: error running workflow [message #870627 is a reply to message #870525] Wed, 09 May 2012 06:59 Go to previous messageGo to next message
Thank you, Holger!
I swear I did lots of cleaning, and scrubbing, and washing. It still was behaving eratically.
But today it worked fine from the first try... Very weird.
best regards,
Vlad
Re: error running workflow [message #870685 is a reply to message #870627] Wed, 09 May 2012 10:46 Go to previous messageGo to next message
Member
Seams like a bug Ed Willink reported seconds ago. We will try to fix
that soon.
Holger
Re: error running workflow [message #870688 is a reply to message #870685] Wed, 09 May 2012 11:01 Go to previous message
No, 'my' bug is different. It's an M7 regression and results in a
slightly different message at slightly different line numbers.
Ed Willink
> that soon.
> Cheers,
> Holger
Previous Topic:put mwe2 and grammar in a different project
Next Topic:need explanation regarding assignments
Current Time: Tue Jan 19 13:03:56 GMT 2021
Powered by FUDForum. Page generated in 0.01727 seconds
