Re: Copy&paste of library items in the designer does not preserve the library dependency [message #870585 is a reply to message #870454] |
Tue, 08 May 2012 20:43   |
What types of customizations do you make. I tried the copy and paste
with a grid in 3.7.2 and it worked.
Jason
On 5/8/2012 6:27 AM, ing omini wrote:
> I have the following issue.
> My rptdesign is using an external rptlibrary in which I define some
> basic formatting for charts.
> When I drag and drop a library item into the design and make some
> customization, everything is ok: the link to the original library item
> is defined.
> That is, in the xml source I have the attribute: extends="mylib.myitem".
> So, changes to the library item will correctly reflect on the item
> instance inside the design.
> Let's call item_X the item instance inside the report.
> When I try to copy and paste item_X to have item_Y, I find out that
> item_Y is NOT linked to the library.
> Of course as a woraround I can go inside the XML source and add the
> missing attribute: extends="mylib.myitem"
> But I would exepect BIRT to preserve this information during the
> copy/paste operation.
> Is it a bug related only to my version (Eclipse BIRT Designer Version
> 2.3.2.r232_20090202)?
> Is there another way of "smart" copying items which preserves this
> library dependency, without changing the xml manually?
> Thanks!
FUDForum. Page generated in 0.01531 seconds
