Home » Modeling » Papyrus » ecore model from .di
ecore model from .di [message #870325] Mon, 07 May 2012 16:14 Go to next message
elhache elhache is currently offline elhache elhacheFriend
Hi All,
I would like to experiment model transformation technologies. ATL, actually.
My ultimate goal is to create a sequence diagram using Papyrus diagram, then, to use
ATL to produce a state diagram model. The final step is to convert the obtained diagram into Papyrus format for visualization.
My Question is : how to obtain (grammatically, or with an existing tool) an ecore model from a Papyrus model i.e., .di ?
I need that because ATL takes an ecore model as input.
Thanks a lot.
el
Re: ecore model from .di [message #871965 is a reply to message #870325] Tue, 15 May 2012 08:23 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
You should not try to convert a Papyrus model to an Ecore model. You should use the UML.ecore metamodel instead.
For your transformations, you should work with *.uml files (ie. the semantic files), which conform to the UML.ecore Metamodel. You can also work with notation.ecore (from ) + *.notation files for your diagram visualisations, although it is probably a lot more complicated (*.notation files are not trivial at all).
UML Metamodel (semantic): http://www.eclipse.org/uml2/4.0.0/UML (UML.ecore, from org.eclipse.uml2.uml)
Notation Metamodel (diagrams): http://www.eclipse.org/gmf/runtime/1.0.2/notation (notation.ecore, from org.eclipse.gmf.runtime.notation)
Camille
Camille Letavernier
Re: ecore model from .di [message #1806928 is a reply to message #871965] Fri, 17 May 2019 23:47 Go to previous messageGo to next message
Khoa Nguyen is currently offline Khoa NguyenFriend
Hi Camille,
I managed to transform the .notation file by using metamodel from http://www.eclipse.org/gmf/runtime/1.0.2/notation. However, some elements are not in that metamodel. It looks like they form UML metamodel. Therefore, I cannot transform them to the output model. Do you know how to resolve this problem?
For example:
I need to transform this to the output model.
<element xmi:type="uml:Activity" href="Test.uml#_LmLfQHeIEemfZ8m9ot-iOA"/>
Thanks.
Re: ecore model from .di [message #1806933 is a reply to message #1806928] Sat, 18 May 2019 06:50 Go to previous messageGo to next message
Do not dump on old threads. Your question may share the keywords UML and Ecore but is totally different.
I wrote a reply, but have deleted it to avoid polluting this thread with speculation about an impossibly vague question. e.g. what tool, what initialization, what activation?
Ed Willink
Re: ecore model from .di [message #1806938 is a reply to message #1806933] Sat, 18 May 2019 10:16 Go to previous message
Hi El,
I try to use ATL to transform multiple Activity diagrams into one Activity diagram.
I can transform the .uml file; however, I not sure which is the right approach to generate the diagram (or .notation file).
I tried with Diagram template plugin, but the diagram is not generated properly. The ControlFlow links are not displayed, some elements are duplicated...
Therefore, I tried another approach which transforms the .notation file as well.
I managed to fix the <element> node problem by allowing inter-model references. I also not sure if it is the right way to fix it. I am still new to Model-driven engineering, Papyrus, ATL...
Thanks.
Khoa
Previous Topic:Use case profile
Next Topic:Cannot create control flows between activities
Current Time: Wed Jan 22 04:37:11 GMT 2020
Powered by FUDForum. Page generated in 0.01975 seconds
