Home » Modeling » QVT-OML » [QVTo] UML 2 UML transform
[QVTo] UML 2 UML transform [message #870050] Sun, 06 May 2012 03:14 Go to next message
Alain Lavoie is currently offline Alain LavoieFriend
Member
I followed with success a tutorial with QVTo. But my objectives is UML
to UML transformation with UML Profiles. I saw previous messages on
Profiles, so I will get there eventually and get back to these.
Meanwhile, the tutorial I used is transforming models produces with
Ecore files From observation of a Papyrus XMI file, the models looks
similar, but I am blocking on a first issues and I cannot find the
solution in the past M2M messages. By the way, Google has a hard time
with the eclipse forum references, I can rely on the Google cache, but
is this a temporary problem ?
Back to my issue, I have
modeltype umlMM uses 'http://www.eclipse.org/uml2/3.0.0/UML';
transformation CIMTransformation(in umlIn : umlMM, out umlOut : umlMM);
main() {
-- umlIn.rootObjects()[umlIn::Package] -> map ...
Q1 - Going to [Operational QVT Project] > [Properties] > [QVT Settings]
> [Metamodel mappings], I cannot find the way of adding a local
reference to the uml metamodel. How can I ?
Q2 - I guess this problem is related to Q1. I do not get Completion in
(Ctrl-space) the transformation file ?
Q3 - Will I have to convert in some way the uml model file (produced
with Papyrus) with a conform ecore file, or it is a valid ecore
file ?
I can read the model with the sample Ecore editor, but I do not
want to assume it is valid.
Regards.
Re: [QVTo] UML 2 UML transform [message #870077 is a reply to message #870050] Sun, 06 May 2012 08:02 Go to previous messageGo to next message
Tex Iano is currently offline Tex IanoFriend
Member
Hi Alain,
the metamodel has to be registered. So install the UML2 package for eclipse. You do not need to add a metamodel mapping. Then you have code completion.
Tex
Re: [QVTo] UML 2 UML transform [message #870115 is a reply to message #870077] Sun, 06 May 2012 17:02 Go to previous messageGo to next message
Member
Hi Tex Iano
Hm, I must be in the wrong menu settings...
Can you indicate me a page from the web, where I can follow
the procedure to do so, or the menu you are talking about ?
Are you refering to the menu listed in my question Q1 ?
Every attempts to insert different flavor of platform:...
failed. What kind of entries should I insert in the
Metamodel mappings source and target uri fields ?
I presume it is already there, since I have Papyrus (UML Modeler)
and QVTo installed. I did though, since you mentionned it installed
the 2 following packages:
+ EMF Compare UML2 Integration
+ UML2 Extender SDK
From Help>Install new software, I cannot find anything else related to
UML2. From the Eclipse Plug-ins list, I seem to have all UML2 related
software, UML2 Model Search Ui, UML2 UML Editor, ...
Still, cannot have any completion (and this indicate me I did not
configured my project correctly) !
Any other hints ?
Thanks in advance.
Re: [QVTo] UML 2 UML transform [message #870119 is a reply to message #870077] Sun, 06 May 2012 17:26 Go to previous messageGo to next message
Member
Hello again Tex,
Now from your previous post, I have the following snippet:
modeltype uml "strict" uses uml('http://www.eclipse.org/uml2/3.0.0/UML');
transformation CIMTransformation(in umlIn : uml, out umlOut : uml);
main() {
umlIn.rootObjects()[umlIn::Package] -> map PackageToPackage();
Now I have the code completion for the umlIn::... but, should
I get a code completion for the qvt transformation fonctions like
PackageToPackage() ?
Re: [QVTo] UML 2 UML transform [message #870147 is a reply to message #870119] Mon, 07 May 2012 03:53 Go to previous messageGo to next message
Member
Alain Lavoie a écrit :
> Hello again Tex,
> main() {
> Thanks
As an add-on to this discussion, from the wiki.eclipse.org/MDT/OCL/FAQ,
I get that ecore is a standalone metamodel that can define itself, and
that ecore can be used to express a UML metamodel. Furthermore, it
seems that UML is already delivered with QVTo. Hm... I still do not get
where the java PackageToPackage method is being defined. I verified
that that ecore::EPackage exist, both should use this definition for
my uml to uml transformation ?
Therefore, what is the equivalent PackageToPackage() in the ecore world ?
Finally, if I rely on ecore mm, I can imagine that I will miss some uml
concepts along the way, that those defined in uml but not in ecore.
Am I right ?
Regards.
Re: [QVTo] UML 2 UML transform [message #870159 is a reply to message #870147] Mon, 07 May 2012 05:28 Go to previous messageGo to next message
Your multiple messages seem to be getting increasingly confused.
I suggest a little more thought before pressing the send button,
otherwise I may start treating your messages as spam.
PackageToPackage is of course a mapping between two classes, so if you
use some other metamodel the parameter types will change.
Ecore corresponds to EMOF which is a simplified form of UML. If you
don't like the simplifications don't simplify.
An EMF mapping might be called EPackageToEPackage.
Ed Willink
>> Hello again Tex,
>> main() {
>> Thanks
> Am I right ?
> Regards.
Re: [QVTo] UML 2 UML transform [message #870255 is a reply to message #870159] Mon, 07 May 2012 13:22 Go to previous message
Member
Ed Willink a écrit :
> Hi
Being alone on a project without any expertise around is a challenge.
I will respect your request.
Previous Topic:Code Completion / Operations in QVT installation
Next Topic:Failed to resolve metamodel when debugging
Current Time: Sat May 08 08:40:06 GMT 2021
Powered by FUDForum. Page generated in 0.02121 seconds
