Home » Archived » COSMOS » Validating test SML-IF documents
Validating test SML-IF documents [message #10390] Fri, 30 May 2008 22:45 Go to next message
Originally posted by: virginia.smith.hp.com
I downloaded the latest stable build of the Resource Modeling Eclipse
Plugin. I grabbed some test SML-IF files from CVS to play with. I cannot
get any of the valid documents to validate. I am getting the following
validation error:
cvc-elt.1: Cannot find the declaration of element 'Course'.
I am getting the same error for the files I've tried - Valid.xml and
RefToNonRoolElement.xml.
Perhaps there is some setup I am missing?
ginny
Re: Validating test SML-IF documents [message #10423 is a reply to message #10390] Thu, 05 June 2008 22:38 Go to previous messageGo to next message
David Whiteman is currently offline David WhitemanFriend
Hi Ginny,
How are you doing the validation? Are you selecting the files in the
Eclipse explorer and selecting Validate SML-IF from the context menu?
Or are you opening them in the editor and selecting the validate link
from the first page of the editor?
David
Ginny Smith wrote:
> validation error:
> ginny
Re: Validating test SML-IF documents [message #10456 is a reply to message #10423] Fri, 06 June 2008 16:32 Go to previous messageGo to next message
Hi Ginny,
I created a Java project and imported the file you tried to validate,
and selected "Validate SML-IF" from the context menu, and I got a
message that there were no validation errors in the document. I'm not
sure if the problem was something in the i10 stable build, but using the
most recent weekly integration build (week 5), and using Eclipse 3.4
RC2, I don't get those (or any) errors.
David
"Smith, Virginia (HP Software)" <virginia.smith@hp.com> wrote on
06/05/2008 06:45:47 PM:
> Both options give me the same errors. I'm attaching one of the files
I downloaded
> and tried to validate.
> ginny
Re: Validating test SML-IF documents [message #10488 is a reply to message #10456] Fri, 06 June 2008 23:23 Go to previous messageGo to next message
David,
I started over with a fresh install of Eclipse Ganymede and then installed
Cosmos.
Eclipse Platform, Version: 3.4.0, Build id: I20080523-0100
cosmos-rm-incubation-COSMOS-1.0.0-200806041150.zip
Here is what I've done so far:
1 - I imported the IF file. I imported as an Interchange file which caused
the IF file to be unpacked. I can successfully validate the Student_xx.xml
file (and all the other xml files if I give them an xml extension). So it
appears that each file in the model is valid itself.
2 - I really want to validate the entire model as an SML model, including
references. I assume that to do this in Cosmos, I must first package the
model into an IF file. Therefore, importing the file into Eclipse as an IF
file (as in step 1 above) is not what I want to do. So now I am assuming
that when you said you imported the file, you meant that you imported the
file directly from the 'file system' and NOT as an IF file. So next I
re-imported the IF file as a generic file.
3 - I opened the IF file just imported and see the IF editor. I clicked on
"Validate the entire document" and got the following errors.
errors:
'Course'. Valid.xml SMLTest1 line 107 Service Modeling Language
'Course'. Valid.xml SMLTest1 line 132 Service Modeling Language
'GraduateCourse'. Valid.xml SMLTest1 line 119 Service Modeling Language
warnings:
The reference Course1 is dangling Valid.xml SMLTest1 line 86 Service
Modeling Language
The reference Course3 is dangling Valid.xml SMLTest1 line 92 Service
Modeling Language
The reference GraduateCourse is dangling Valid.xml SMLTest1 line
89 Service Modeling Language
Is Ganymede a problem - could there be a conflict?
Is anything else needed other than Cosmos SML component?
How about my java version? I have JRE 1.5.0_13 and 1.6.0_06 installed on
my system. In Eclipse, I have only the JRE 1.5.0_13 listed in the
Installed JRE preferences and set as the workbench default but how can I
be sure what Cosmos is using. Note that when I run "java -version in a DOS
window" - I get the 1.6 version returned so 1.6 is the default on my
system.
Thanks for your help!
ginny
Re: Validating test SML-IF documents [message #10520 is a reply to message #10488] Tue, 10 June 2008 00:50 Go to previous messageGo to next message
Hi Ginny,
I too am using Ganymede, and am using the Sun JRE 1.5.0_13. I believe
the JRE that is used to run Eclipse (which would include running plugins
invoked by menu options) would be 1.6, since you have not overridden the
system default when starting Eclipse. The one listed in your
preferences only affects Java programs you launch from within Eclipse,
and the JRE used in compiling code that you write. So basically, all
code you got from Eclipse (including COSMOS) is running 1.6, and all
code you wrote or run in your workspace is using 1.5.0_13.
Just to try and eliminate the JRE from being a variable here (I would do
this myself, but I don't have 1.6 installed on this machine), try
modifying which JRE is used to launch Eclipse. You can do this in
Windows by selecting eclipse.exe, right clicking and selecting Create
Shortcut. Then edit the shortcut and add "-vm <path-to-JRE-1.5-VM.exe>"
to the end of the Target line. For example, I have the following in my
Eclipse shortcut:
c:\eclipse-34-RC2\eclipse\eclipse.exe -vm
C:\work\Java\jdk1.5.0_13\bin\java.exe
Let me know how this goes for you...
David
Ginny Smith wrote:
> David,
> installed Cosmos.
> caused the IF file to be unpacked. I can successfully validate the
> Student_xx.xml file (and all the other xml files if I give them an xml
> extension). So it appears that each file in the model is valid itself.
> including references. I assume that to do this in Cosmos, I must first
> package the model into an IF file. Therefore, importing the file into
> Eclipse as an IF file (as in step 1 above) is not what I want to do. So
> now I am assuming that when you said you imported the file, you meant
> that you imported the file directly from the 'file system' and NOT as an
> IF file. So next I re-imported the IF file as a generic file.
> on "Validate the entire document" and got the following errors.
> errors:
> cvc-elt.1: Cannot find the declaration of element 'GraduateCourse'.
> warnings:
> line 89 Service Modeling Language
> DOS window" - I get the 1.6 version returned so 1.6 is the default on
> my system.
> ginny
Re: Validating test SML-IF documents [message #10553 is a reply to message #10520] Wed, 11 June 2008 20:38 Go to previous messageGo to next message
Thanks, David. That solution took care of the errors. (So Java 1.6 is a
problem.)
However, I am still getting the warnings:
Modeling Language
Modeling Language
It looks like the baseURI is not being processed correctly. A different
test file, ValidRule.xml, validates with *no* such warnings. In this file,
the baseURI does not cause problems since all sml references point
directly to the document alias (i.e., either the baseURI is universally
applied or is never applied - it makes no difference).
(Also note that the SML spec has changed terminology. "Dangling"
references are now "unresolved references".)
ginny
Re: Validating test SML-IF documents [message #10586 is a reply to message #10553] Thu, 12 June 2008 01:10 Go to previous messageGo to next message
Thanks, Ginny, for your patience and investigative work. If you don't
mind doing so, please create a bug report and attach your SML-IF file as
a test. Here's the URL for entering a bug; choose component =
ResourceModeling:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Cosmos
I went ahead and split the difference with you by creating a bug report
for Java 1.6. :-) Please add yourself to the cc: list if you want to be
updated on its progress.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236772
Thanks!
David
> problem.)
> file, the baseURI does not cause problems since all sml references point
> ginny
Re: Validating test SML-IF documents [message #10619 is a reply to message #10586] Fri, 13 June 2008 18:27 Go to previous message
David,
I submitted the bug today.
ginny
Re: Validating test SML-IF documents [message #571163 is a reply to message #10390] Thu, 05 June 2008 22:38 Go to previous message
Hi Ginny,
David
Ginny Smith wrote:
> validation error:
> ginny
Re: Validating test SML-IF documents [message #571173 is a reply to message #10423] Fri, 06 June 2008 16:32 Go to previous message
Hi Ginny,
David
I downloaded
> ginny
Re: Validating test SML-IF documents [message #571253 is a reply to message #10456] Fri, 06 June 2008 23:23 Go to previous message
David,
Cosmos.
errors:
warnings:
Modeling Language
Modeling Language
system.
ginny
Re: Validating test SML-IF documents [message #571279 is a reply to message #10488] Tue, 10 June 2008 00:50 Go to previous message
Hi Ginny,
Eclipse shortcut:
David
Ginny Smith wrote:
> David,
> installed Cosmos.
> errors:
> warnings:
> my system.
> ginny
Re: Validating test SML-IF documents [message #571328 is a reply to message #10520] Wed, 11 June 2008 20:38 Go to previous message
problem.)
Modeling Language
Modeling Language
ginny
Re: Validating test SML-IF documents [message #571346 is a reply to message #10553] Thu, 12 June 2008 01:10 Go to previous message
ResourceModeling:
Thanks!
David
> problem.)
> ginny
Re: Validating test SML-IF documents [message #571398 is a reply to message #10586] Fri, 13 June 2008 18:27 Go to previous message
David,
ginny
Previous Topic:Validating test SML-IF documents
Next Topic:help with MDR creation
Current Time: Wed Jul 28 21:34:02 GMT 2021
Powered by FUDForum. Page generated in 0.02609 seconds
